Thread: changing engine fan on e28?
    Default changing engine fan on e28?
    One of the blades on my engine fan is broken. I have a replacement but how do I get the thing off? I took off the 4 bolts but the disc it's attached to won't come off the engine. It's an 83 528e. Thanks for any help.
    -M
    Minnesota
    Does anyone know whether those cars had a fan clutch? if so, you have to take the fan clutch off and the fan comes with it, then remove the clutch unit.
    Hopefully someone here will know this...
    Canada, ON
    Oh yes they did, BMW likes the fan clutch idea.
    How do I take the fan clutch off?
    -M
    Minnesota
    Probably that reverse thread 32mm nut, sometimes a few good wacks will loosen it up. If you have the belt off you'll need to find some way to hold the spindle steady while turning that big nut. Remember, "righty loosey" this time, due to reverse threads.
    Good luck.
    Ork weapon time?
  1. changing battery in key
    Last Post: 09-20-2009, 10:01 PM
  2. Changing from 20d or 25d engine to 30d engine (E39)
    By btc530d in forum 5 Series BMW
    Last Post: 03-21-2008, 08:32 PM
  3. DIY on changing spark plugs in M50 engine
    By ktteoh in forum 5 Series BMW
    Last Post: 05-22-2007, 12:41 AM
  4. changing steering box
    Last Post: 12-08-2006, 11:17 PM
  5. changing oil filter in between oil changes
    Last Post: 05-12-2006, 09:32 PM
