ball joint does not have to come off to replace the struts. Just the 3 bolts on the bottom, the sway bar link bolt, and the 3 bolts on the strut tower. When those are off, you can pull the bottom of the strut assembly towards you and it will come out leaving the ball joint attached. The rears are just simply the shock bolt and the 3 tower bolts under the parcel shelf.
