Results 1 to 10 of 13
Thread: transmission oil
    Sep 2004
    Default transmission oil
    what do you guys recommend for transmission oil?
    Default Trans Fluid?
    what trans do you have???
    Depends on what car you have.
    Default What fluid!
    Whatever it is, synthetic is the way to go!
    "Uncle" Phil C
    2011 Kia Optima EX-P.
    Former owner of a 95 525i 5spd. "The GQ" aka A Shark in sheeps clothing
    03 R1150RT 6spd. "DaRTth"
    00 R1100R 5spd. "LeRoy"
    West Palm Beach, South Florida
    I use AstroGlide. Says right on the bottle 'Caution: AstroGlide is VERY slippery. Clean all spills immediately'. I figured it would be a good lubricant for the transmission. Boy, the lady at Walmart looked at me like there was something wrong with me when I walked up with the 25 bottles I would need to fill the car.
    Dayton, Ohio
    How do you change/check tranny oil???
    Former: 95-530iM
    Current: 99 GMC Seirra 1500
    Gainesville, FL
    Quote Originally Posted by PhilipJCaputo
    on your car (mine toooo!) there is no dipstick.. Its complicated. You have to have the ATF fuild at a certain temp to check it using a little drain hole somewheres. Its in the bentley manual in greater detail. i'm thinking i'll just take mine in to get it done.
    Sep 2004
    '90 535im - my brother thinks it's time for a change, just dunno what to use
    Albuquerque, NM
    Default Did mine tonite . . .
    The official factory spec for the Getrag 260/6 used in all e34 535i's is Dexron II which is no longer available (at least not that I'm aware of). Dexron III is the replacement and is fully backwards compatible with all automatics that call for Dexron II. I'm a bit skeptical using Dexron III in a manual trans since it is a synthetic blend and synthetics can cause premature syncro wear. Many e34 owners highly recommend Redline MT or Redline ATF or a mixture of both. Redline fluids are high quality fluids but they are 100% synthetic, and I cannot say how they do in the long run.
    I'm experimenting with many different types in mine & the jury is still out. I bought a used trans last fall, out of an 88 735i, same Getrag 260/6 trans, with 130k miles on it & it had GL-4 gear oil in it. I changed it to Amsoil ATF, also full synthetic. It did well thru the winter but didn't feel right so switched to Amsoil 80W GL-4 in the spring but toward the end of summer, 2nd gear syncro didn't feel right. It wouldn't grind & it downshifted flawlessly but was very notchy going from 1st to 2nd at higher rpm's. Then I switched it to Swepco 201 80W90 which is a very high quality petroleum gear oil recommended for Porsche 915 transaxles, in the fall & that felt great, but now that colder weather is upon us, it's a b*tch to get it into 1st & 2nd for the 1st 1/2 mile in the morning, shifts fine after 5 miles & shifts great when it's fully warmed up, but it's not going to cut it in the winter so I surfed the web for petroleum manual trans oil recommendations & decided to try Pennzoil Syncromesh, which is an 80W gear oil but not a GL-4 spec. It's a custom formulation for GM to address syncro issues they've been having with their New Venture manual trans & also resolves 3rd gear syncro issues in 90's vingate Mitsubishi manuals & some 2nd gear syncro issues in Toyota 4-runners. It's supposed to be a very high quality fluid & has the consistancy of a 5W30 motor oil & is supposed to retain a low viscousity down to minus 40F.
    It's interesting to note that Bentley's e28 repair manual says that 20W or 30W motor oil is perfectly fine in the older Getrag 260, 260/5, & 265 trannies, the only catch is it requires more frequent seasonal changes to keep the right viscosities & temps matched. The preferred fluid for them was 80W90 GL-4 which has the equivalent viscosity of 30W motor oil. It was around 88 or so that Dexron II became the spec for Getrag manual trannies for e28's & e24's, same trans as ours, just different drain & fill plugs to differentiate them & some even had a label on them stating Dexron II.
    I just got back from a quick 5-mile drive to work the Pennzoil in & curious to see how it does in the morning after sitting cold overnite. I'll report back Sunday after a long drive, to give it time for a fair assement, so far it shifts very smooth with no syncro issues.
    gale
    Tampa Bay, Florida, USA
    Here's how you do a 5HP30, in the 540s. Not sure if it's applicable to other models
    http://www.e38.org/zf-5hp30-service.html
    Ramon
    1994 540iA Nikasil EAT Chip
    Tampa Bay, Florida USA
  1. Transmission Oil
    By Roderick in forum 5 Series BMW
    Last Post: 01-03-2007, 05:29 PM
  2. New transmission...Again...
    By Montreal525 in forum 5 Series BMW
    Last Post: 07-07-2006, 09:24 PM
  3. 323 transmission
    By scott540 in forum 3 Series BMW
    Last Post: 01-17-2006, 07:35 PM
  4. What transmission do I have?
    By olsan100 in forum 5 Series BMW
    Last Post: 10-05-2005, 04:20 AM
