Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Best Brake Pad Choices
    I use Axxis MetalMaster... Rock solid braking performance with zero dust and zero fade. I have PBR Ultimate on my other car... Ultimate is ceramic and is dusty... one fuel tank is one week OEM pad.
    As for the Brake fluid... the reason they have blue and gold is so when you flush them out... you can tell where old fluid ends and new come out. It's the same stuff with different coloring. You definitely need to bleed your brake system... 540i brake are monster!
    Default I try Raybestos QS
    I've used PBRs/Axxis deluxe and semi-mets, on a total of 3 different 525i's, I cannot get them to stop squealing. I run the semi metalics on the E30 and have a hard time getting them to squeal even after the abuse of a track day (not a good track pad). On the 5, the last pads were EBC and while quiet and dust free, the rears didn't last too long, maybe 30 to 40k. The fronts are doing better. I replaced the rears and will replace the fronts with Raybestos QS pads and have been happy. Don't have long term-life test results. The Raybestos QS are easier to come by and are cheaper.
    Warren
    91 318is
    95 525iT
    Default the real lowdown on brake pads from Bill R...
    Copied the following text, which was written by Bill R, a long time ago and kept it for just such an occassion.
    I wasn't going to get involved in this discussion, since with some people brake pads are like religion... However after watching the pad posts recently I couldn't keep my big mouth shut.
    I have installed literally thousands of sets of pads on cars and trucks. These are strictly my own observations.
    Jurid : Good pedal feel, low noise fairly rapid wear and dusty. Good street pad if you don't mind dust and lifespan.
    Pagid: Ditto jurid, virtually the same thing.
    Mintex: Jurid , Pagid clone, slightly less dusty.
    Still good pedal feel, doesn't require a lot of pressure. These three are all good street pads with dust.
    Performance friction and Performance friction z rated: This pad I have installed around 30 sets. I have not yet had a customer who was happy with them on a street car in the long run. Greater pedal effort, noise and buildup on rotors and warped rotors. I have ended up taking off every set I have sold for the street. (note, none of these were on bmw's however for what thats worth)
    A couple of friends who race s.c.c.a. stuff use the z rated on the track and are happy with them. they typically change them after one day at the track.
    Autozone duralast: Lifetime warranty, high noise level. Hard pedal feel. Fairly agressive on the rotors Very few people happy with these, although I do install a lot for the type of person who is oblivious to the brakes on his car. The car as appliance type of people. Not recommended by me.
    Axxis Metalmasters:
    I install a fair number of these. good pedal feel , low effort, lifetime warranty, low fade. Low noise and very little dusting.
    PBR Metalmasters:
    I didn't realize there was a difference in these until I got a set from Patrick and realized the compound looks different from the Axxis metalmaster. I haven't installed them yet so no opinion.
    PBR Deluxe. Average pad, low dust, not the greatest pedal feel or stopping power. A good average pad for normal duty use.
    Raybestos PG Plus: Lifetime warranty pad, low noise very good pedal feel, good stopping power, low dusting. I have installed about 30 sets of these on varying makes in the last 3 months and have been very pleased with the results. I have had no comebacks with these so far...I am going to try a set on my 535 instead of the metalmasters I ordered because of the results I have had on other cars. They have a satisfaction warranty as well. If you install them and aren't happy with them they will refund your money. I would try the next grade up which is a ceramic pad but its not available for bmw yet.
    Hope this helps.
    His words, not mine...
    Grace and peace,
    Robert K
    Chicago
    PBR and Axxis may be the same company, but may not have the same compounds. Yes the metalmasters under both brands are known to be noisy. The Axxis Ultimates is a kevlar-ceramic compound and it does NOT squeal. Besides the usual dust (less than stock), everything else is better, heh well less longevity. Though it still lasts long, pad bite, coefficient of friction, noise, pedal feel, temp range, cold pad bite, etc. are much much better. Here is a link for a comparo to the Deluxe Plus, Metal Master & Ultimates: http://www.zeckhausen.com/axxis_pads.htm#Compare
    Semi-metallics with any brand have been known to squeal, that is why they headed towards the ceramics. One thing I did notice, contrary to the graphs, is that on several cars, including e39 and e34 M5 brakes, the noise is actually a lot less on the ultimates than the Deluxe PLus. The Deluxe plus tend to squeal under light load and slow moving. The Ultimates just don't squeal!
    The graphs sometimes have to be interpreted. I have noticed that the fade is equal for the PLus and Ultimates on the graph, but that is in the operating range of the pad. The Ultimates have a much higher operating range and thus does not drop off in performance like the Plus. Also, regarding rotor life. I have noticed that I as well as others have acquired glaze spots on their rotors. Well, that is because the pads, such as the Plus and other pads in its temp range (low dust type), can have a tendency to glaze to mirror like finish under our performance use... performance tuned cars. So, you could easily damage a rotor from one spirited drive and then the rotor would have a much shorter life. That also goes true for throwing away glazed pads in regards to pad life.
    I cannot say enough about the Ultimates for the performance enthusiast They are just awesome. Oh, one last thing, every Stoptech kit comes with Ultimates.
    The stock Pagid or Jurid are still very good, they just don't have as much bite, are very dusty, cost more and have a lower temp range than other pads out there.
    Quote Originally Posted by WarrenBrown
    Warren
    91 318is
    95 525iT
    Brandon J
    CT
    Thanx Brandon!
    King Of NYC
    chicago (NOT chicagoland)
    Default Like both the ultimates and metalmasters.
    Yeah a little late to the party......
    A set of Metal Masters on the SE-R and a set of Ultimates on the 3er.
    I installed both sets myself (ok drivers side on the 3er) and have NO squealing whatsoever. New rotors but reused shims and springs. And we are very anal about proper bed-in here @ Pablo's Garage. It's fun too.
    Haven’t had a chance to track either myself tho. They do need the slightest bit of warm up for good bite. Just slightly soft in the 1st application or two of a drive, nothing dangerous. After that they’re grrrreat. Nice modulation, good feel, i like em both.
    Final choice would depend on any price difference and whether one is planning any track visits.
    I have a set of dedicated race pads for the Sentra (u wanna talk squeal and rotor wear *rolleyes*) so i feel set either way.
    93 SE-R ‘Jenny’---94 530iT&A ‘Helga’---92 325i ‘Rolf’ ….”Hang up & Drive!”
    ”It is not the function of our government to keep the citizen from falling into error;
    It is the function of the citizen to keep the government from falling into error."--Robert H. Jackson.
    I agree... Axxis and PBR is not the same material.
    CT
    A couple more brake questions...While I focus on my brakes, I may as well do everything necessary to make them optimum-- If I need to consider rotors, why go with the stockers? Any of you guys use the Brembo rotors? I don't expect them to work like a big-brake kit....but is it worth the brand name? There are others like Zimmerman that are cross-drilled; aside from dissipating heat better, are there any other advantages? And secondly, I want that instant strong, effortless kind of brake response you can get from an E39 or E46. Would stainless steel brake lines make a difference? Anybody done it? Worth $100?
    King Of NYC
    Chicago
    If you want that new braking feeling...it exists on the e34. You should bleed the brakes well, install new rotors (if needed), and new pads. I always use the anti squeal goo on the backing of the pads. 1mm of wear is big on a rotor. It will have less mass to absorb the heat from braking so in theory can run hotter. If you doubt the thickness of your rotor and you plan on installing new pads anyways, just buy new rotors. They aren't that expensive and you will be sure that you don't have to worry about it. Remember that you should NOT use used pads on a new rotor. You could use NEW pads on a used rotor.
    As far as rotors go, there are numerous brands that are OEM, Zimmerman, Brembo, Balo. These are all good, just don't get the cross drilled ones. They have less surface area and thus reduces braking efficency. With performance pads, like the Ultimates, fresh brake fluid, and rotors within spec, you should not have any over heating problems...even in very sporting street driving. I lost my brakes once while playing with an e39 M5. I didn't bleed my brakes in a year and was using Axxis Deluxe Plus pads. I bled my brakes using Ate Typ 200 and switched to Ultimates. No problem since.
    Properly cooling the brakes is really done via brake ducts and that is probably the next step if you plan on driving on the track. Cross drilled rotors even crack on the track. Brembo uses slotted rotors as the fix on their brake kits for the cross drilled. Stainless steel brakelines can hold for now. Start with the pads, rotors and fluid. The brakelines can be added at a later time. There are benefits and drawbacks so while you install the other brake components, you can do further research on the lines, what is good, what is bad, and which brands to trust.
    Stick with the stock set-up, just improved via performance pads and brake fluid. It is a good set-up and it will not disappoint you.
    Quote Originally Posted by rockyfeller
    Brandon J
  1. Wheel choices?
    By scoop2004 in forum 5 Series BMW
    Last Post: 06-30-2008, 12:25 PM
  2. What are my Tire Choices?
    Last Post: 03-28-2008, 01:39 PM
  3. diff choices!
    By stevie s in forum 5 Series BMW
    Last Post: 02-11-2008, 08:58 AM
  4. Differential choices for V8 cars...
    By MTechnik540i in forum 5 Series BMW
    Last Post: 08-02-2007, 11:55 PM
  5. Reputable manufacturers and part choices
    By Rus in forum 5 Series BMW
    Last Post: 02-04-2007, 09:05 PM
