Results 1 to 7 of 7
Thread: How to remove thrust arm / control arm ball joint?
    PA
    Default How to remove thrust arm / control arm ball joint?
    I seriously cannot get the upper/thrust control arm ball joint to come out. i got the 22mm bolt and nut off without dropping the frame by using a box wrench and dropping the impact gun from the topside of the engine bay down... but i cannot for the life of me get the ball joint out. i have pickle forks and a tie-rod puller, but the puller doesn't quite fit over the strut plate and such... what to do?
    chicago (NOT chicagoland)
    A regular ball joint pickle fork is too wide, the narrow tie-rod fork works better.
    Oh and a 3 pound sledge hammer (minimum) to pound on it.
    Some PBblaster/liquid wrench might help or some here have taken a torch to it.
    93 SE-R ‘Jenny’---94 530iT&A ‘Helga’---92 325i ‘Rolf’ ….”Hang up & Drive!”
    ”It is not the function of our government to keep the citizen from falling into error;
    It is the function of the citizen to keep the government from falling into error."--Robert H. Jackson.
    PA
    Quote Originally Posted by paul p (chi-town)
    do I pound inward like jabbing at it? or downward like prying on it? i have new arms and bushings so i dont give a **** about the old ones, but i dont want to bend the plate the ball joint is attached too... and tthen when installing a the new ball joint, is it going to be this damned hard but backwards?
    Mar 2004
    It is a royal pain to get these apart - in my case only the LAST one was terrible - spent 3 days and finally the answer was swing harder. By the way, I damaged the hardened steel ball joint remover, that is how tough it can be to seperate these bad boys.
    Good luck,
    Scott
    1995 BMW 525i w/139K miles, EAT Chip - (Gone)
    07 525i 22K, 07 328xi (41K)
    1982 Mazda RX-7 w/147K miles (Back again!)
    Default I used a #20 to get mine loose and ended
    up heating the knuckle with my aceteline torch before it would pop out!
    Default Agreed. Big hammer good..
    I ended up having to go out and buy a bigger hammer. I think i took the nut off then bolted the knuckle back to the car and beat the crap out of the pickle fork for a day or so....
    Best of luck.
    Bill
    PA
    Figured it out, made a little thinger bobber, check it out
    http://www.bimmer.info/forum/showthr...1260#post41260
  1. Removing the Thrust Arm Ball Joint
    By Adnan in forum Suspension & Steering
    Last Post: 02-04-2021, 09:03 PM
  2. control and thrust arms with replaceable ball joints???
    Last Post: 07-02-2009, 11:03 AM
  3. Replies: 9
    Last Post: 11-12-2006, 10:28 AM
  4. Removing the Thrust Arm Ball Joint
    By Adnan in forum 5 Series BMW
    Last Post: 08-19-2004, 05:34 PM
  5. Replies: 0
    Last Post: 03-24-2004, 04:34 PM
