Originally Posted by
Mr. BILL
I compared the two t-stats and I was wrong, thinking the one I had in there oartially opened. I did a side by side test and they both open all the way.
I'm going to check the fan clutch, then pull the radiator and have it tested.
I don't think it is your fan clutch. IF the radiator doesn't get hot the fan clutch won't engage.
Ok, you have a M20 engine, what you willl do is the following:
Open the thermostat screw then blow with your mouth where the radiator cap goes until only clear coolant comes out. Close thescrew and stop blowing.
Do the same with the screw on the rad.
The M20 is very hard to bleed. Took me 1 hour last time I tried....
Make sure that you have the heater open also.
If the car overheats and you have no heat: AIR IS TRAPPED either from not bleeding enough or headgasket/cylinder head/block problem.
