Results 1 to 5 of 5
Thread: Help please!! Replacing transmission mounts
    No. California
    Default Help please!! Replacing transmission mounts
    and can't jack tranny high enough to remove front mounts. The car is on stands and when I jack up the transmission too much it lifts the car off the stands. Do I need to loose motor mounts? I am also repalcing center bearing and flex disk so the drive shaft is out. The rear mounts are already loose.
    Any help is appriciated.
    Thank you
    Kurt
    95 525ia
    Nashville, TN
    front mounts ?? I thought the trans was bolted to the engine and the only mounts were on the rear of the trans !
    Derek A.
    90 535i 5 Speed - Style 5 17"
    No. California
    There are two mounts in front right behind the sway bar. I figured how to replace.
    Jul 2004
    Vancleave, MS
    Default Last weekend....
    I jacked up the engine (wood on jack at oil pan) enough to swap motor mounts... while the engine was up, I was able to easily remove the front tranny mounts... perhaps try lifting from the engine? Rx'd the wrong parts though so I'll be doing it again next weekend....93' 525ia @128K. What prompts you to replace them? I'm just doing my engine/tranny mounts because...I can? Cheers, Rob.
    Quote Originally Posted by KurtM
    Thank you
    Kurt
    95 525ia
    Jul 2004
    Vancleave, MS
    Default ...doing it because I get a nasty vibration and figure...
    ...changing mounts won't hurt; but I'm not convinced it will cure the vibration, will wait and see. good luck.
    Quote Originally Posted by RobPatt
  1. Replies: 3
    Last Post: 02-27-2009, 08:08 PM
  2. Replacing Rear Shock Mounts... Procedure.
    Last Post: 02-11-2008, 07:33 AM
  3. My UUC Track transmission mounts came!
    Last Post: 08-19-2005, 04:23 PM
  4. Auto Transmission Mounts
    By Mewsy in forum 5 Series BMW
    Last Post: 11-30-2004, 07:25 PM
  5. Transmission mounts upgrade with OEM???
    By Bruno in forum 5 Series BMW
    Last Post: 04-13-2004, 10:45 PM
