unless you had other plans
there are 2 orange sensors under the hood, one on each fender under a plastic cover (I think) thats the bugger that lit the fuse on you. Disconnect the battery when you put the new one on.
to get the system active it will need more then a bag, the clock spring under the wheel will be roasted and the control unit is usually toast too, depending on the year the seat belt retractors could be blown, which ever sensor that hit may need replacment too
i put a bag out of a audi on it's face and set it off from behind cover, ****er jumped 75-100' in the air, now that's power
Originally Posted by dcbimmer
