Hi,Originally Posted by silverz06vette
Not too sure which particular part you are talking about but the receptacle is a two piece assembly. There is a case and a "holder" that are joined by a hex bolt at the base of the seat. You will probably need to remove the seat to get at the bolt but once it is out the pieces should seperate with light pressure. Good Luck.
Best,
Rory
