Results 1 to 10 of 12
Thread: wont start- spark plug mangled!
    Sep 2004
    Default wont start- spark plug mangled!
    I put a new starter in a 1990 525i 5spd I just bought. Never saw it run. Now it cranks but still doesn't start. At first I thought it also had a broken timing belt becuase it doesn't sound to have good compression when cranking, but I see the camshaft spinning through the oil fill hole when cranking.
    Pulled the spark plugs and tested spark. Has spark. 1 plug looked great. 4 oil fouled and one of them was smashed! The electrode was flattened and knocked over and the tip was even pushed to the side! Does this mean that my M20 has interfered in the past, has bent valves or somehow shrapnel got in the cylinder?
    Henry Helfman
    Meridian, ID
    Did you try a compresson check when you had the plugs out. If you don't have compression, particularly on the cyl with the smashed plug, then you probably have bent valves. Bent valves probably from timing belt. My guess is you are looking at a valve job, some new valves, new timing belt, new water pump while you are in there.
    Mike Holbrook
    Meridian, Idaho
    smashed plug is a NO GO. sounds like its a little more severe than bad gas over there. Could be anything from a busted valve head to a shrapnel piston. whatever the cause that thing needs to be yanked and replaced or rebuilt as necessary.
    Last time I saw a smashed plug a valve head rolled out the header with about 2 gallons of antifreeze.
    windows are cool as long as they arent in your block.
    Take pictures!
    baton rouge, loserana
    ditto
    Take pictures!
    Sep 2004
    I dont get it.
    But yeah I was worried about that. Didn't have my compression tester handy at the time but I did the ol' "finger compression test" on that that cylinder and didn't feel anything when it was cranking. Didn't bother with the other 5. I just want to see this thing fire. Cant see why it would still have a timing belt if it bent valves previously. Will be away this weekend but pics coming monday!
    Looks like I'll be parting the car or selling whole. Where should I advertise? Want this thing out of here ASAP!
    Default Windows
    is a term used when there is a hole through a cylinder wall and the block is unreparable.
    Sep 2004
    Default i really hope this isn't the case
    Do these M20 motors crack the block a lot? How can I tell?
    Wellington,New Zealand
    Default the sort of damage jeff is talking about
    is very obvious...aka leg outa bed...rod out the side.....
    Gone but not forgotten
    Sep 2004
    I didn't notice any holes/cracks on the outside of the block. I wouldn't have bought it if I saw something that obvious.
    what's the telltale sign? How are you so certain it's not a top-end problem?
    Default did you pull the head yet?
    that would tell a tale
  1. What is that and what has it done with my spark plug?
    By dauchande in forum 5 Series BMW
    Last Post: 09-22-2010, 07:59 PM
  2. Spark plug
    By specialguess in forum 5 Series BMW
    Last Post: 04-14-2010, 10:00 AM
  3. spark plug application chart, plug gap, torque
    By shogun in forum 6 Series BMW
    Last Post: 10-15-2009, 12:33 AM
  4. E28 Wont Start - No Spark
    By Jimmy535i in forum Engine & Drivetrain
    Last Post: 07-12-2004, 08:19 AM
  5. NGK Spark Plug
    By kentish in forum 5 Series BMW
    Last Post: 06-03-2004, 08:47 AM
