Results 1 to 8 of 8
Thread: Theoretical Trans fluid question 5hp-18 530 trans
    Default Theoretical Trans fluid question 5hp-18 530 trans
    what would happen or what would be the reccomendation say if someone (not me of course) changed filters and accidently added 1 qt redline dextron II instead of the dextron III as recommended. Stupid labels look almost identical. Should my friend be worried or no biggie?
    Minnesota
    Jeff,
    I guess your "friend" will find out, but, probably safer than being a quart or so low! What is that about 10% of the total volume? I suppose your "friend" could always drain it again and "dilute" it further with the proper fluid.
    Benneton (United Colors of)
    alright brian boitano....it can't hurt too much, esp. if its redline, according to this......
    www.nmia.com/~dgnrg/atf3a.jpg
    Mar 2004
    Since it's not your transmission, tell your "friend" not to worry about it. You can give us regular updates about any future problems and we'll add to the knowledge base.
    Paul Shovestul
    Default hahaha
    Quote Originally Posted by Bellicose Right Winger
    Paul Shovestul
    Default guess according to that couldnt be worse
    than mixing synthetic motor oils and weights...
    UT
    When you figure a 7.8 liter capacity, that quart is just around 10%. I don't see much likelyhood of problems. Tell your friend to purchase reading glasses.
    Default i think it holds more than that,
    im lookin at 4 qts just in the pan and its at least 1 qt low, add in the trans and torque converter and Im sure its over 10 qts.
  1. another trans fluid question
    By bmwrp8 in forum 5 Series BMW
    Last Post: 02-13-2009, 11:34 AM
  2. Trans. Fluid
    By Bimmer93 in forum 5 Series BMW
    Last Post: 12-14-2006, 09:44 AM
  3. Esso LT 71141 Lifetime trans fluid question?
    Last Post: 06-22-2006, 06:51 AM
  4. auto trans fluid change question for a e36 328i
    By BigKriss in forum 3 Series BMW
    Last Post: 08-09-2005, 09:36 PM
