Results 1 to 4 of 4
Thread: angle torque-ing
    Default angle torque-ing
    whats the reason for the angle torquing required when re-installing the head??
    Mar 2004
    Austin, TX
    I don't know, but I did mine today. I made my own guide by drawing a 4" circle on a piece of thin cardboard (that comes with the headgasket), and marking a line at !2"00 and 3:00, or 90*. I made a mark on my extension and my son held it in place and told me when to stop. Worked fine.
    Good luck!
    i just do a 1/4 turn by eye, i will not be using torque to yield bolts when i build my monster m20 (soon i hope) race tech studs through out, pricy but cool. i usually use my snap on dial type torque wrench and i've seen the TTY bolts break (not actually snap, but release) anywere from 55 to 90 flbs usuallu theres almost 20 lbs difference across the motor
    Mar 2004
    Angle torquing is more accurate then a conventional torque wrench. It eliminates the effect bolt-thread and bolt-head-washer friction has on torque wrench accuracy. It's use on both conventional and torque-to-yield bolts.
    Paul Shovestul
    Quote Originally Posted by kiNGMak
  1. Angle eye head lights
    By 535Bimmer92 in forum 5 Series BMW
    Last Post: 05-22-2007, 02:14 AM
  2. Angle torque question
    Last Post: 01-26-2007, 01:44 PM
  3. Dip beam angle adjustment.
    By Dan in NZ in forum 5 Series BMW
    Last Post: 09-26-2004, 08:44 PM
  4. Cam angle changes and effects on compression
    Last Post: 08-20-2004, 04:04 PM
  5. Where to buy angle torque tool?
    By Craig in forum 5 Series BMW
    Last Post: 06-28-2004, 02:34 PM
