Results 1 to 7 of 7
Thread: Brake Pressure warning from OBC.Help!!!!!!!!
    Mauritius
    Default Brake Pressure warning from OBC.Help!!!!!!!!
    Hi to everyone,
    Just went for a little ride in my car and when I was two blocks away from home, got a warning from the OBC, Brake Pressure-See owners manual.
    Brakes seems to be normal.
    When I reach home, I depress brake pedal several time and the brake pressure message appeared again.
    It seems to be linked to number of time I press brake pedal.
    Anyone can help me
    Kentish
    540iA 1994 176000km
    baton rouge, loserana
    does your car have vacuum boosted brakes or hydrallic, if hydro there may be a failing sensor or part in the boosting system, if vacuum i have no idea, our us cars don't have any brake pressure sensors that i've seen
    Mauritius
    Its vacuum boosted brakes as in all 540i I think. I hope its a sensor failing .When depressing the brake pedal, I can hear pump kicking in to produce the air but after a few seconds I get the message -Brake Pressure from the OBC. May be there is a leak or sensor not working as the brakes are normal.
    Kentish
    Mauritius
    Hi Winfred. I made a mistake, The Brakes are hydro brakes. No vacuum present. I can hear air being pump but just few seconds afterwards, I got the warning from OBC and then it disappear.
    Kentish
    this could be the begning of a problem, a bad connection or a dieing sensor, i've never worked on a v8 with hydro as our cars have vacuum, the parts should be much the same as the earlyer 6 cylinder cars, there should be a distrubution block with a pressure switch or two and somewear there should be a accumulator aka "bomb" it's about a 4" black metal ball this is what gives the brake pedel it's give, it could be failing, what happens when a bomb fails is it fills up with fluid and the nitrogen leaks out and the brakes get harder and harder as it fills up
    Mauritius
    I am thinking the same. Someone told me that if this Pressure accumulator goes wrong , the brake pedal will fill harder to depress. I suppose it could be that part. Fortunately its available at the dealer for around $200. I checked all other parts linked to brake system. Apart from some small leak, everthing is okie and no fault code is coming out of the diagnosis plug.
    Thanks a lot for the help Winfred.
    By the way, i thought that all V8 engine has hydro type brakes and there was not enough space in the engine compartment for the Vaccum servo to be installed. am i correct
    Kentish
    they stuck a dual servo vacuum unit right behind the left headlight with a linkage going to the firewall on the e32/34 v8s here
    Quote Originally Posted by kentish
    Kentish
  1. Low oil pressure warning
    By 632 Regal in forum 8 Series BMW
    Last Post: 03-14-2023, 09:01 AM
  2. Oil pressure warning.
    By bbig119 in forum 5 Series BMW
    Last Post: 08-02-2006, 08:02 AM
  3. low pressure oil warning
    By ram5757 in forum 5 Series BMW
    Last Post: 02-21-2006, 02:50 PM
  4. Oil Pressure Sensor Warning
    By uscharalph in forum 5 Series BMW
    Last Post: 08-23-2005, 11:30 AM
  5. oil pressure warning!
    By Mike in forum 5 Series BMW
    Last Post: 03-01-2004, 08:19 AM
