Results 1 to 3 of 3
Thread: "Check Control"
    Houston TX
    Default "Check Control"
    My 89 735il has "Check Control" pop up on control screen most of time when I start it....goes out. How can I check it????
    I'm really starting to like the 7....really fun to drive...and soo smooth compared to my 535i.
    Callen 91 535i 94 530i 89 735il
    I have the same with ignition position 2, plus 'see owners manual' followed by 'catalysator'. Then it goes off after the 'bong'. (maybe this is because I have a japanese version. Could be different by country depending on local specs, same like the stomp test is only required in USA)
    Have it since years and no problem. Checked with my dealer here in japan, he says it's normal, just a checking function of the systems.
    Used the PEAKE last weekend, did not find any faults.
    So should be o.k.
    Machine runs smooth.
    Albuquerque, NM
    Default "Check control"
    Could be a weak battery, corroded battery posts, or the instrument cluster in need of "the capacitor fix" (least likely culprit). One way or the other the voltage is down just after releasing the starter, letting the gremlins sneak in when the unloader relays latch in.
    gale
    92 735im
    gale
  1. Check Control Malfunction--"Door Open"
    By Chris in Laguna Beach in forum 5 Series BMW
    Last Post: 07-05-2005, 01:19 AM
  2. On the sevice display it reads "check control"
    By old bob in forum 5 Series BMW
    Last Post: 04-30-2005, 08:07 PM
  3. "Check Control" error message on the display?
    Last Post: 02-09-2005, 09:44 AM
  4. "Check Control Owners Manual"
    By chagm in forum 5 Series BMW
    Last Post: 12-07-2004, 03:51 PM
  5. "Owner's Handbook" displayed on Check Control
    By phildg2000 in forum 5 Series BMW
    Last Post: 06-21-2004, 11:26 AM
