Results 1 to 7 of 7
Thread: where to buy a tie rod puller?
    SF Bay Area, CA
    Default where to buy a tie rod puller?
    time to work on the front end...
    where did you buy yours?
    tia,
    mike
    just about any autoparts place has em.
    if you don't do a lot of suspension work Mike, there is no need to buy any puller or pickle fork. Many autoparts stores have rent/lease/buy/refund with no out of pocket costs upon return...I used Murray's puller and separate pickle fork kits when rebuilding a board member's front suspension not long ago....all you need. I do own the relatively inexpensive tie-rod puller sold by Bavarian Autoworks...a nice little puller that works perfectly for the tie rods...won't work on the bigger control arm ball joints on these cars though.
    HTH,
    George
    Dayton, Ohio
    George, you got a part number for that "inexpensive" tie-rod puller??
    I need to do some suspension work......
    Former: 95-530iM
    Current: 99 GMC Seirra 1500
    SF Bay Area, CA
    Default ? a tool that works on tierods & control arm joints?
    is there a tool that works on control arms & tie rods? (so I can just buy one tool?)
    BavAutoW has a tierod puller for $40. was that the one you mentioned?
    thanks,
    mike
    HTH,
    George[/QUOTE]
    Philip...I don't have a part number but if you go to BavAuto's website...you might find it..runs about $40 as Mike mentioned..perhaps a bit less. As to one puller Mike doing everything...maybe...maybe not...you may get lucky and find such a beast. I tend to like horse's for courses...why the rental/return kits are the ticket...when you tackle one of these suspensions...it is nice to have a menu of tools to use as the ball joints on these cars as most know can be very stubborn.
    George
    Mar 2004
    Here the kit that I got (recommended by Brandon).
    I was able remove all of the ball joints and tie rods with these tools.
    Here
    Nice set to have in the tool collection. You may need to use some heat in conjunction with the pullers. Good luck.
    Mike S.
    1992 535iM black/black
    1997 540iM white/gray
    Retired: 89 535iA, 85 318i
    <<Support your local autobahn, stay out of the left lane!>>
  1. my new beer can puller prototype
    Last Post: 01-27-2008, 09:22 AM
  2. Subframe bush puller
    Last Post: 10-22-2007, 01:24 AM
  3. Tie Rod End & Pitman Arm Puller
    By 525e34 in forum 5 Series BMW
    Last Post: 06-09-2006, 05:09 AM
  4. I got my hands on a subframe puller tool
    Last Post: 05-30-2006, 07:30 PM
