Stiffer ride due to different spring rate.
Will swaybars from a 540I fit a 93 525ia? And will they benefit the 525ia
Sorry previous post had springs and I meant swaybar...rofl oops
And your nose will be up in the air, rather snobby!
The 4.0 is a heavier motor, so the springs will not be matched well to the 525. Not a good idea.
--Micah O'C
'17 M2 6MT, Mineral Grey
'04 330i ZHP
'88 M5 2791445
'92 M5T BL01001
formerly '90 535iM, '92 525iT
Unless you are going for that Porsche Cayenne style...
it should not effect ride height(rh), in fact i swapped all springs and sway bars from a 540 sport onto my 535 and did the [1] rears first, raised it slightly,[2] sway bar front next, no change except better cornering feel, [3]rear sway bar next, a little better feel no chane in rh, then lastly [4]the front springs which lowered rh (about 3/8")and stiffened it up a bit.
LOL, how this happens at times cracks me up, not reading what your seeing?
We responded when it said springs...
Originally Posted by Tiger
I edited it I told 632 Regal I my mind has been detached of late..
632 Regal is already supplying my springs... I'm having to redo the whole suspension due to the miles..159k. I believe that the shocks have never been replaced. You should feel the baby dance on uneven pavement. I brought the car with 77k on the dial..
