Results 1 to 3 of 3
Thread: Belt Tensioner Removal: 1995 525i, M52
    Default Belt Tensioner Removal: 1995 525i, M52
    On a 1995 525i, M52 motor, how do you remove the fan belt tensioner. I am trying to isolate a squeal. At idle, the car sounds like the engine compartment is full of cicadas. It's embarassing at the stop lights.
    Here's what I have done so far:
    First the easy part. I removed the A/C belt. The squeal remained. Then I removed the fan belt and ran the engine briefly with no belts. The squeal is gone. Both belts are relatively new and in good shape.
    With the belts off, I manually turned the water pump, steering pump and alternator pulleys. They all appear to be in good shape. As does the stationary idler pulley on top. But the belt tensioner pulley seemed a little loose, as if the bearings are worn out. So I thought, "Aha! here's the source of the noise. All I need to so is replace the pulley and the cicadas will go back into hibernation." To double-check I swapped in the pulley from the A/C tensioner which is the same part but appears to be in better shape. Ran the engine and the squeal came back. So now I suspect the tensioner itself. This suspision is enhanced by the fact that when I yank down on the belt from below, and thus compressing the tensioner, it makes a creaking sound as it compresses.
    So back to my questions: How is the fan belt tensioner attached to the engine? It's hard to see in the narrow space between the radiator and the engine. Do the water pump and the tensioner share a bolt? Will the water pump have to come out? Bentley doesn't mention it and a search of the archives didn't yield any info. Is the tensioner a likely candidate for a squeal that goes away above idle? Anyone replaced their fan belt tensioner recently?
    Thanks for any input.
    Eric Fraser
    Austin, TX
    just a few bolts on the tensioner assembly, you have to remove the pulley to access one of the bolts. Pop off the plastic cover on the front of the pulley and remove that bolt.
    1994 540iT/6 - 316k miles, 4.0L, 6spd, UUC Evo 2, Bilstein HD's, etc.
    1995 540iA M-Sport - 73k miles. 1 of 1 auto AW3 cars.
    2006 330i - 131k miles, wife mobile.
    Default got it out!!
    thanks, that's a relief. might as well replace the two pulleys as well.
    ps. for the archives:
    the tensioner is held by two 13mm bolts. i removed both tensioner pulley and idler pulley for easy access to the bolts.
  1. Belt Tensioner Location
    By saj3n in forum 5 Series BMW
    Last Post: 03-09-2006, 03:06 PM
  2. m50 belt tensioner, quick q..
    By romeox929 in forum 5 Series BMW
    Last Post: 12-16-2005, 05:53 PM
  3. belt tensioner question
    Last Post: 11-30-2005, 03:42 AM
  4. Cooling Fan Removal:E34 1995 525i M52 Engine
    By Eric Fraser in forum 5 Series BMW
    Last Post: 09-05-2004, 05:29 PM
  5. AC belt tensioner needs replacement
    By Phil M in forum 5 Series BMW
    Last Post: 03-17-2004, 09:13 PM
