Originally Posted by
netmgr
The wipers are speed sensetive and go to reduced speed when you stop.
However if you select the very top setting this overrides this and the wipers go at full speed wether youre stopped or not.
So if they work normally on top speed then check your speedo...when you drive does it register on the speedo? if it does then sounds like gremlins in the controller for wiper speed. if no speedo either then check speedo implulse sender....but im guesing this is not the case or you would have mentioned it...unless youre trying to stop the car clocking up miles...but no one would do that!
darren
