Is it possible to adjust the clutch pedal on an E36? I know that you can change the clutch stop, but the pedal is too high on the race car...
I know that on the E34 you have an excentric that you can adjust, what about the E36?
if the end is not screwed on, a sloted bracket should get the job done, find the position you like and weld up the excess hole and grind smooth, maybe add a piece of extra metal to the back side for strength
