Results 1 to 10 of 18
Thread: 535, manual tranny and 3.76 and 3.91 rear ends
    Default 535, manual tranny and 3.76 and 3.91 rear ends
    I think a few of you guys (JoeS, Robin, Dave R, others?) are running either a 3.76 or a 3.91 rear end. I'm considering upgrading and am trying to decide which one I want.
    I'm leaning towards the 3.76 unit as I think the 3.91 is a bit too short. Likely makes first gear pretty unusable.
    Can I get some comments from you guys who are running the shorter rear ends on what you like / don't like about the ratios? Street vs. Highway, usablity of the gears, other comments...
    thx!
    Jeff
    Bellevue WA
    86 Porsche 951 - Track Toy
    Jeff, what is the current stock gear?
    Default 3.46 (n/t)
    Bellevue WA
    Australia
    Aussie spec 535i manuals have a 3.64...
    Q
    Aug 2004
    Milwaukee, WI; Chicago, IL
    That's what I've been wondering.
    Default I put a 3.73LS in at the beginning of summer.
    It's a noticeable improvement. I do a lot of highway driving and don't mind it at all. 80mph = ~3500rpm IIRC. Dave Rutkowski has a spreadsheet to calc that stuff, and I volunteer him to give you the rundown in each gear.
    Whatever you do, don't do what Martin did.....he really missed the boat by going with a 3.64
    Default Agreed Scott, yet another bad decision on my part. Let's not learn anything, eh?
    Jeff has driven my car with the 3.64 enough to be afraid of the 3.91 or lower gears. That 3.64 lsd trigger was pulled with the knowledge that it was from a low torque m20 in good condition; it was a good price, and it was replacing an open 3.4. It is too bad there isn't a close ratio gearbox reasonably available for the m30.
    Took the fam on a weekend trip to west WA. The 535 is great on those 2 lane roads. The roll on power in 4th really shines with the maf & that 284 cam. The brake squeal seems to be gone with the Bav Auto brass caliper bushings. The front 850 calipers have Hawk hps pads.
    Quote Originally Posted by Scott H
    blah blah blah...
    erased due to slander
    Default sheesh Martin, testy today?
    Quote Originally Posted by Martin in Bellevue
    blah blah blah, brag brag brag.......brake squeal
    Default It is tough watching friends make the same mistakes that I made years ago.
    I'm just upset because I care.
    Run you bastard, RUN!!!!
    Apr 2004
    Monrovia, CA
    Martin, as an FYI -
    I have those in my Z3 Roadster - be sure that you keep a maintenance schedule on those to keep them lubed. I had a caliper 'stick' because I got a bit too lazy with that, wore down 1 of the pads and scoured a rotor. (driver's side outer, obviously not the side with the sensor). So now I make sure to pull off the wheels, clean the guide pins/bushings and throw some hi-temp anti-sieze in those things every 3 oil changes (about 9500-10k mi).
    They are great, but they are NOT a non-maintainence item.
    Eric
  1. anybody got a line on a manual tranny for a 850 e31?
    By winfred in forum 5 Series BMW
    Last Post: 05-25-2007, 11:53 AM
  2. Replies: 2
    Last Post: 04-23-2007, 09:29 AM
  3. What's the best (manual) tranny oil to use?
    Last Post: 11-26-2005, 08:39 PM
  4. M30 manual tranny question
    By hamada in forum 5 Series BMW
    Last Post: 03-29-2004, 07:02 PM
