Results 1 to 3 of 3
Thread: Can the E38 Oil Pump Chain be tightened?
    1/2 Way tween Chicago & Milwaukee
    Default Can the E38 Oil Pump Chain be tightened?
    I remember last time when I checked the oil pump bolts on my e38, I mentioned here on the board that the bolts were loose, someone had said that I should have also tightened the tension on the oil pump chain. Mine seemed to have a lot of play.
    Well, I have the pan off now, and I'm trying to tighten the chain and can not seem to figure out how to do it. I even checked out http://www.e38.org/
    I'm talking about a 1997 740i btw.
    Hmm, am I missing the obvious?
    Default Here you go Ed.
    Quote Originally Posted by Bimmer Nut Ed
    Kisses to you Bill R. Thanks again as usual. I just did not notice that it really is a "big" hex fitting in there. 8MM, inside that passenger side bolt hole (after you remove the bolt). I had removed the bolt and still could not see it. The validation in the ETK image made me persist. Thanks Bill. Yeah, I know, the ETK is the first thing I should pull out, and here I did it again, it was last. Part of my problem is, my cousin installed it on my PC in German, and it's a real pain to weed through the German to find the location to change it to english. It always defaults to German when I bring it up! Thanks all.
  1. Fuel pump gone; Opel pump fit in BMW?
    Last Post: 09-27-2009, 08:51 PM
  2. timing chain and oil pump replacement
    Last Post: 07-27-2006, 04:35 PM
  3. Oil pump chain tighteing
    By infinity5 in forum 5 Series BMW
    Last Post: 07-12-2006, 06:27 PM
  4. Replies: 9
    Last Post: 11-07-2004, 12:18 PM
  5. OT - Over tightened drain plug on wife's Cougar
    By dave b in forum 5 Series BMW
    Last Post: 10-31-2004, 06:40 PM
