I have heard of this upgrade. Is it for the 95 525i as well? How expensive and how difficult to install?
Originally Posted by Messerschmitt
Just for kicks, I ordered the upgraded EPROM for my 530ia tranny and installed it today.
I'll have to say that it did make a worthwhile difference. It was supposed to eliminate the 4th/5th gear pendelum shifting and go back into high gear faster after a kickdown downshift. So far it seems better. I'll post later after some time in the drivers seat.
Messerschmitt
The part number for the new EPROM for the ZF-5HP18 is 01 00 1 469 310
It was introduced to cure several "customer complaints" at once.
I'll see what I can find out about your transmission
Messerschmitt
...I was getting trans prog error messages... code said it was a bad fluid pressure regulator. Replaced that ($90 part) and a bulletin said there was an associated EEPROM update (another $90) (perhaps changing valid fluid pressure values); no problems since.... about 8 months and 4K miles. , Rob.
The EPROM cost ~20.00 and it only takes maybe 20 minutes to replace. It's inside of the transmission control module in it's socket with a plastic cover. Really easy to replace. However, you will need the correct part number
Messerschmitt
Was that $20.00 from a stealer?
Does this chip work on the 540 5 speed auto tranny also?
1995 540iA - 1988 535i 5 Speed
1980 528i 5 Speed - 1980 528iA (Sold)
Thanks - sure would like to know
Originally Posted by Bob in San Jose
TIS only lists 530ia and touring for this upgrade. If you have a 530i I really think it is worthwhile.
Messerschmitt
Bob, when you shift to 4th gear from (ED) in your 540 does it jerk really hard? My 94 540iA does.
94 540i- 2.50 HP Racing exhaust, 2 3/4 lowered,18.8 HP Evo's,
88 325ic- AC Schnitzer chip,3' lowered ,M3 body kit, 17.7 TSW Ribs
Michael A. Johnson
Mighty Mike's Sound & X-cessories
MRBMW1
