Take some pics.
When's the dyno run/tunning?
Hmm.... to sell the 535 and get a 330 or WRX or Mini or whatever.... or to keep the 535 and turbo it....
Now that I have the installation complete and am on the way to being dialed in I know it is time to let the forum know how TCD's kit goes together and works.
I drove from Toronto to meet Todd in Springfield MA, we had a great car guy chat and swapped some cash for the first E34 kit. And, he took me for a blast in his 325; pretty impressive. That was Friday August 1, I arrived home at 11:00PM after 1500 km. The kit was in and on the road late afternoon Sunday....I would have been quicker had I listened more closely to Todd and made fewer mistakes.
Before the turbo I had done the necessary MAF, cleaned up and port matched the head but not much else to the engine. My last dyno pull on a local DynoJet gave me just over 191 HP at 5300 and 215 pounds of torque at 4300. You can convert that to at-the-crank if you want, however, it is at the wheels that moves the car.
I am now in tuning mode, running intentionaly rich with lots of timing retard and the soft spring in the wastegate. The plan is to get the mixture as close as I am able and then move the timing back up. My car was pretty quick before and I am not there yet, at only 7 pounds boost and the results are amazing. I drive the car are tracks here in southern Ontario, (running with Bruno) at my last outing an instructor who was driving a supercharged late model Mustang commented that he was surprised at how little he pulled on me up the back straight....next year I will be pulling away from the Mustang.
Other mods I have made, strut brace, 850 brakes all 4 corners, H&R springs, RD Sway bars, Bruno's rear mount stiffening plates and a 3.73 Diff. and I had a custom clutch made pre turbo...a modified M5 unit with Kevlar facings.
The kit is great, super fit and finish, I have only met Todd, but if you want to work with a guy who has passion and loves his product....TCD is it.
Cheers,
Dave
Take some pics.
Curious about your set up...you mentioned you installed the necessary MAF...why is adding a MAF versus stock AFM necessary for a turbo install...aside from its programability? Second, you mentioned that you are playing with your A/F and timing retard. What kind of device have you added to the motor that gives you the lattitude to supercede both A/F and ignition timing of your Motronic engine management...aside from changing your EPROM?
Congrats.
I will get pictures organized, at least a few over the next couple days. The focus is an upcoming track day on the 20th and everthing has to be ready to run to the rev limiter all day long.
I guess I wasn't clear....I had added the MAF over a year ago, and they are a necessary upgrade for a naturally aspired car. Stock you will see around 175 at the wheels, add a chip and you are in the 181 range, at least I was, but with the MAF you add another 10 HP. The but is the big torque number and great drivability. Regardless as I have the MAF it seems to me that I will only make more power with few restrictions, so I am not going to revert to stock.
I am useing a piggy back laptop based tuner which intercepts a number of signals from the sensors on their way to the DME.
Dave
No, you were clear, just misguided. There is nothing necessary about a MAF upgrade for either a NA or turbo car. I should know, I worked with Bruno on his MAF development for the M-30. A MAF however is directionally correct for more horsepower and are less restrictive and more tuneable and offer better transient response but the stock AFM is clearly adequate for either application and whatever slight horsepower impairment can easily be compensated for.
Please explain to me what sensor or sensors your laptop intercepts from your DME to interpret/alter ignition timing retard or advance accordingly.
Misguided, OK, however you should assume a little tongue-in-cheek as my comment is intended. The MAF was necessary to me and I am pleased with the result on all levels regardless of the fact that the AFM is perfectly functional - I just wanted the thing!
I am intercepting and modifying the signal from the MAF, partly to compensate for 2 things, the differing signal and the fact that I am running beyond the air flow at which the flapper is pinned open, and the pulse from the crank position sensor. I am also monitoring voltage from the O2 sensor. This gives me fuel, timing, engine speed and air fuel ratio, at least as well as a narrow band allows.
Dave
Good stuff Dave.
No offense on the misguided comment...a matter of semantics...know what you mean about just flat wanting something. :-)
Please share with us the piggie back engine management program/interface...company and model you have...perhaps a link if you have it...I am sure interested. Sounds like a powerful piggie back system with so much capability....probably fine to run off a narrow band O2. Bottom line is being able to tweak both air/fuel AND ignition timing...sounds like your system can do both.
I would like to hear how you interpret air/fuel but in particular how you have settled upon what you consider a retarded ignition timing curve. Did you establish a stock baseline initially and then offset the ignition timing curve accordingly?
Let us in on how the system works a bit...how much richer than stoich you are running for example until you hone in on a safe but efficient A/F.
What do you estimate your horsepower increase running 7 psi?
Congrats again and sounds like a lot of fun.
George
Hi Dave, I was wondering what piggyback chip you happened to be using, and where you were able to get ahold of it. I was looking at unichip, but there doesn't seem to be much documentation online, and since they're SAfrican, getting in touch with them is... troublesome.
Thanks!
Custom Turbocharged 1991 535iM - 135k mi.
My piggy back system is an SMT-6 from Perfect Power in South Africa. Have a look at http://www.perfectpower.com
