Detailing is gratifying to be sure. For future reference, I suggest you reconsider your approach. Mothers makes nice products but what you really want to do is polish your paint. Glaze contains silicones and fillers and is more like "make up" to cover the cosmetic imperfections of the clear coat which is fine to a point but doesn't address the root cause of the reflective quality of your paint...you have to polish it. Next time consider instead of camoflaging the imperfections in your clear coat with glaze...level the clear with a couple step polishing process. Starting with a medium polish and finish with a fine polish. Since you own an orbital...this goes pretty quick.
Most glazes are sealers and you really don't need a sealer if you are going to wax. Most top detailers apply wax by hand as all the prep to create the highest reflective surface is done mechanically with the orbital and polish prior to wax. Einszbett polishes are reported to be about the best out there...what I suggest. You don't want to use a cleaner wax after this step...go with a simple high end pure carnuba...like a P21S for example. I have no doubt your car looks great...just FYI for the future.
