I'm using the split second narrow band (0.2 ~ 0.8V) air fuel ratio meter. It conditions the signal enough to make relevant readings, I think. It is tapped off the stock sensor wiring in the black plastic housing over the injectors.
I'm curious if anyone is running one on their E34. Jeff has one, but the readings seem to be way low... maybe because it's in his glove box?
Robin
72 Chevy K10
01 E39 M5
erased due to slander
So that snoops the stock O2 voltage and converts it to an a/f ratio using a programmed look-up table?Originally Posted by Martin in Bellevue
I'm looking at a $55 data acquisition card that sticks onto your laptop's parallel port and can record 8 analog and 4 digital (TTL) signals... Couple that with a plug that taps into the motronic input and you should be able to read the O2 signal, timing advance, pulse duration, RPM, throttle signal, IAT, head temp, and maybe MAP...
I'm itchin to know what all that stuff reads as I drive down the road. You could also to dyno pulls with that information plus some math.
Anyone know what the G-Tech will record?
Robin
72 Chevy K10
01 E39 M5
Robin...you likely know this...A/F gauges working off of a conventional narrow band O2 sensor are marginal at best. You would be better served with a WBO2 set up such as Autometer sells...much more accurate for tuning A/F...what a lot of the NO2 boys use to tune their wet systems to prevent running too lean with a window switch or at WOT. You would have to install a separate bung/WB02...incidently watch your bung hole if Kobe is around :-)
Do you know where the DME interface plug is that taps into the Motronic you mention?
I figure I can start with the stock reading and add the WBO2 in parallel (temporally, not electrically). My fear of the stock O2 sensor is that it's so non-linear that I'd need a good calibration to reverse the ratio from the voltage.Originally Posted by George M
I'd planned on just using the main plug to the DME chassis, looks like a big SCSI plug kind of. I'll have to fab a male/female/splice piece if possible, or splice into the existing cable... which I don't want to do for originality's sake.Do you know where the DME interface plug is that taps into the Motronic you mention?
Robin
72 Chevy K10
01 E39 M5
I think you want one of these.
http://www.innovatemotorsports.com/lm1.php
Wideband sensor replaces the narrowband. E-box has an output that conditions the signal to mimic a narrowband. No need for a new bung, second sensor, second set of wiring, anything.
Price is pretty right. Has logging. Only bummer is that you have to pony up another $120 for the RPM cable if you really want to ship lambda logs to guys like Mark D.
Jeff
Bellevue WA
86 Porsche 951 - Track Toy
