take it to an AC guy :-)
First check to see if it needs a charge. If not, bend over :-)
Hey guys
my a/c is blowing warm air.. what do i do to fix it?
thanks!
-inc
'91 e31 850
'90 e34 535
'02 CBR F4i stunt/track bike
'07 gsxr 750 stunt bike
George - Are you right! Go to someone, get a free diagnostic and if it needs a re-charge, go get a kit from NAPA.
1992 BMW 535i - New Headlights, cold air intake and Supersprint Exhaust
Marc
kidding a bit Marc since no info was provided in the initial post. You can first check the spy glass under the plastic trim by removing the thumb screws on the passenger side over and above hooking up gauges to see what the pressures are. The AC systems...like many other facets of these cars are quite robust...mine is all original on my 150k mile car...still R-12...car sits alot and hasn't been charged in 6 years of ownership....amazing.
George - Mine's a 1992 with 190,000KMs with the original gas still in system and cold. Blower's a little weak, but hey, you only need it here two months of the year!
Marc
Incantation,
Unless your AC system has been retrofitted with R134a you will have to have a qualified shop recharge your R12. If it was retrofitted to 134 you can get a kit with a guage and refill it yourself. It is very easy.
This spring I had my 535i recharged with R12, needed about 2 1/2 pounds and cost a bit over $100. Try to find a good indy shop to do it, they're much cheaper.
Good luck.
how do I check the spy glass? I am not familiar with checking a/c pressure...
-inc
'91 e31 850
'90 e34 535
ok.. hmm.. off to bmwe34.net to see how to retrofit
thanks for all the help guys! much appreciated
-inc
'91 e31 850
'90 e34 535
you guys ever think that maybe the aux fan is causing the compressor not to kick on? mine did that
Sort of off topic but maybe i can bring this up now ; My 1990 535iA has a problem with the A/C Compressor, intermittently the clutch bearing(?) will kinda lock up making the belt squeel real badly - Anybody been up this road? Can I have the compressor rebuilt or look for a new one?
Its a 1990 535iA
18" Hamann HM2's for sale PM me for details.
