i have a 1995 530i. i recently replaced all of my front end linkage. i also have the problem of havnig a hard time turning the wheel, almost as if my power steering pump is not operating! but i'm writing to tell you that if you havn't replaced the upper strut mounts your should. they really can't be tested, they just wear out. if i recall you said you had 65,000 miles on your car if so, and the mounts haven't been replaced, i would do so. it made a BIG difference in my car. it's not that tough a job, just invest in a good quality spring compressor and a 22 mm deep well closed end wrench. regards, bob in houston
