Results 1 to 10 of 16
Thread: Noise from motor. Vanos?
    Mar 2004
    MASS
    Default Noise from motor. Vanos?
    Got a '94 525. When the engine is warm there's a mechanical sound from the Vanos area that sounds like it has something to do with the timing chain. Every now and then it stops when idling but then comes back. Is this the Vanos noise?
    baton rouge, loserana
    sometimes you get some chain/tensioner noise out of m50s, i've never figured out the "vanos rattle" theres nothing to rattle with the vanos unit, it's just a bearing and piston
    the vanos unit can pick up slight play. I had this problem and BMW has a "kit" out that includes a few washers that just remove any excess play, thus quieting the vanos unit. Worked great for me
    NC
    Default I've seen someone post this answer before, but with no reference to part numbers...
    Quote Originally Posted by MotoMan
    Do you happen to have any part numbers for this "kit"? My Vanos has been growling for 2 years now.
    Bill B.
    Bill B.
    95 525i
    Quote Originally Posted by billb
    Bill B.
    Bill hi,
    i will get em for you this w/e and post monday for you, take care
    NC
    Default Just wanted to remind you of this, Motoman...
    Bill hi,
    Bill B.
    Bill B.
    95 525i
    Bill B.
    Bill hi again,
    the part numbers are as follows : 11361403824 stud, 11361403822 disk, 11361403823 disk, 361403550 diaphragm spring. Please note these numbers are as supplied by BMW South Africa. I sure hope this assists you.
    I must admit when u see the parts, all 4 of them, and so damn small, u wonder just what justifies their price.
    Take care
    NC
    Bill hi again,
    Take care
    That's exactly what I was looking for. Bill R., have you seen this before? Looks like a thrust-type rebuild kit for the Vanos, to keep it from rattling back and forth in below-engagement speeds...
    Whatcha think?
    Online ETK link to page
    Bill B.
    Bill B.
    95 525i
    Mar 2004
    MASS
    Default Thanks for the picture and P/N's. Is it easy to figure out installation?
    The Parts are called out in the list but not placed in the diagram.
    NC
    Default Here's the screenshot from a later build '95 525ia
    Quote Originally Posted by Gooch
    I put in 12/95 as build date, and here's what comes up:
    later model vanos kit
    Would any veteran M50 guys take a gander and comment on whether you've seen this setup before? It looks like it adds 4mm of thrust washer, and a diaphragm spring between the two thrust washers. Wonder how it looks assembled? Anyone have pics of a later model M50 (late '95 build) head in the VANOS area?
    Might be worth investigating...
    Bill B.
    Last edited by billb; 07-28-2004 at 05:31 AM. Reason: veteran's spelled with an "n", not a "l"...d'oh
    Bill B.
    95 525i
  1. Replies: 0
    Last Post: 12-16-2007, 01:28 AM
  2. Replies: 1
    Last Post: 12-16-2007, 01:19 AM
  3. Replies: 1
  4. Replies: 4
    Last Post: 01-12-2007, 05:56 PM
  5. Replies: 0
    Last Post: 01-12-2007, 04:10 PM
