usually you can clean it up with just a couple parts, one's easy and the other is a bit of a bitch. the cup is under the shift boot and can be replaced in about 10 minutes with a lift if you know what to do (i leave quoteing the on a jack time to somebody without a lift) if you can move the shifter up and down the cup will definately help. any further slop will requier a deeper fix, the rod from the shifter and the knuckle that it's atached to will restore the shifter to stock, the rod is easy the knuckle is a bitch, id do the cup and see how it feels
