Results 1 to 8 of 8
Thread: 525 Just Stopped!!!
    Default 1990 525 with NO FIRE!!
    I have a 1990 525 and yesterday while driving it simply stopped running. The starter turns and there seems to be power to everything but still no fire in the engine. Anybody have this happen so I know where to start... Ignition coil, distributer, fuel pump? Any help would be greatly appreciated.
    Default Somebody give me a clue!
    Quote Originally Posted by carolina525
    Unregistered Guest
    Default i had it happen very recently actually
    and a mechanic told me it was my crank sensor. So I bought a new one and it turned out my old one wasn't bad it was just dirty. so I cleared the dirt and it fired up. If there is any way to get a mechanic to it they have a little tool that tests for exactly what part is giving you the problem. I still have that crank sensor too if you find out its that and need one.
    Tetsuo48
    Default It was the ECU when it happened to me
    My 92 735iL suddenly died while cruising down the highway. I cleaned the crank sensor to no avail. Changed the coil and that still didn't help. Finally changing the ECU fixed it.
    NY
    This happened to my old 525i, and it turned out to be a burnt wire in the harness.
    Custom Turbocharged 1991 535iM - 135k mi.
    Unregistered Guest
    Quote Originally Posted by AllanS
    This happened to me last week, it was the fuel pump. Driving around no problems next thing, loses power, then cuts out.
    The AA were right on it in diagnosing the fuel pump and when my mechanic checked it, sure enough it was.
    A new one in NZ plus fitting cost me $NZ800.
    Jul 2004
    Tauranga, New Zealand
    Quote Originally Posted by Unregistered
    sorry, this post was me, didn't realise auto login was not working.
    lets try seeing if you have spark, then fuel then post again?
  1. odometer stopped at 300k
    By Mendozart in forum 5 Series BMW
    Last Post: 11-01-2008, 02:41 PM
  2. A/c stopped working
    By DukeNeverwinter in forum 5 Series BMW
    Last Post: 10-13-2005, 04:12 PM
  3. overheating while stopped
    By pong in forum 5 Series BMW
    Last Post: 10-10-2005, 12:57 PM
  4. Car stopped running
    By wailerwoo in forum 5 Series BMW
    Last Post: 08-14-2005, 09:50 AM
  5. Help ... Engine stopped and never started again
    By grave77 in forum 5 Series BMW
    Last Post: 08-13-2005, 12:00 PM
