Results 1 to 5 of 5
Thread: How much would it cost to rebulid a 535i 89 engine
    Unregistered Guest
    Default How much would it cost to rebulid a 535i 89 engine
    I was looking at a 535i 5spd and it looks good but it has 205,000 miles and i was wondering how much would an engine rebuild cost.
    Near San Francisco, CA, USA
    Default As rebuilds go, these are among the cheapest BMW, but...
    At 205K, you could go another 100K or a lot more before needing rebuild. You need to be sure the coolant has been changed regulary, and of course the oil. If the car has a generally good (and known) maintenance history, 205K is nothing to fret over. If there are no records and no signs of routine maintenance, I would shy away from it.
    Quote Originally Posted by Unregistered
    As Warren correctly stated...if you haven't bought yet, simply look for another example with fewer miles. Have a compression test performed and determine if it using any oil. There are exceptions but rule of thumb on the venerable big six is...a head gasket every 150k miles or so and a bottom end rebuild every 300k miles with good maintenance. Dam things have almost as much integrity as 18 wheelers only a bit faster :-)
    George
    Central NJ - USA
    also if u decide u're ready to rebuild, check out metric mechanic
    they sell some kits engine kits for our m30 motors =]
    I would be more worried about other things than an engine rebuild at that mileage. The manual transmission and suspension will probably need to be worked on before the engine, if they havent been replaced recently. I bought my 535i at about the same mileage. and my engine is still going strong at 233k+ miles, but quite a few other things have been replaced along the way...
    Good luck,
    DanH
    1989 535iA 254k Miles
    1992 535iM 330k Miles
  1. 535i Engine Problems
    By BIGJO in forum 5 Series BMW
    Last Post: 10-07-2007, 02:48 AM
  2. Cost of 535i 5spd linkage bushes
    By DavidU in forum 5 Series BMW
    Last Post: 02-18-2006, 02:30 PM
  3. 535i engine cover
    By KingSix in forum 5 Series BMW
    Last Post: 03-24-2005, 05:23 PM
  4. how much does a used e34 525 or 535 engine cost?
    By PABLO in forum 5 Series BMW
    Last Post: 09-25-2004, 11:38 AM
  5. 535i Engine Problem
    By Rory535i in forum 5 Series BMW
    Last Post: 03-16-2004, 08:48 PM
