Results 1 to 5 of 5
Thread: Anti lock
    Unregistered Guest
    Default Anti lock
    I just got a "anti lock" warning light. Would it cause by brake pads going
    bad?
    anyone had this problems?
    Thank you.
    Minnesota
    I know on my '89 325iC I occasionally get the "anti lock" warning even after changing pads and rotors. When the pads were nearly gone I got a brake pad warning, different warning. Not sure why the "anti lock" warning comes on. As I understand it, the brakes still will work fine, just no "anti lock" function when warning light is on.
    baton rouge, loserana
    you may have a sensor going bad if the light doesn't come on till you start moving
    Unregistered Guest
    My light comes on when I start the car.
    I have a 1995 540.
    may be relay or some other hard part problem, get someone to read the codes and see what's pissing it off, the system does a self diagnostic on start up and turns the light off if all's well
    Quote Originally Posted by Unregistered
    I have a 1995 540.
  1. Anti-lock light on
    By Spasso in forum 5 Series BMW
    Last Post: 09-10-2009, 06:11 PM
  2. anti-lock light weirdness
    Last Post: 07-02-2008, 09:15 PM
  3. Anti lock light on
    By Matt in forum 5 Series BMW
    Last Post: 08-23-2004, 06:09 PM
  4. Anti-lock brakes locking up
    By mjfeeney4 in forum 5 Series BMW
    Last Post: 05-15-2004, 06:01 PM
  5. Anti-lock light on, '94 540iA
    Last Post: 02-18-2004, 06:38 AM
