Results 1 to 4 of 4
Thread: BMW alignment pin / wheel centering, tool kit
    Default BMW alignment pin / wheel centering, tool kit
    ever asked yourselves for what that metal pin in your tool box is? # 71111093774
    The BMW tool kit is quite handy for routine maintenance. This particular post will focus on the wheel alignment pin.
    By now, any BMW owner who has removed their wheels will tell you that the wheels are held on in place by bolts. This differs from most American cars which have studs protruding from the wheel hub providing the wheel fastening through nuts.
    Because BMW uses bolts, it can be difficult to align the lug pattern from the wheel to the hub. The procedure may not be hard on a 14" wheel from an E30 but larger 19" wheels on late models are heavy and cumbersome. The front wheels are most difficult to align when you try to spin the wheel to align the pattern but the entire hub just spins with it.
    Luckily the OEM BMW tool kit has a unique tool to aid you in the wheel installation process. There is a metal pin in the toolkit that has many functions but its use in this particular example has the purpose of aligning the wheel to the hub.
    How to use the BMW wheel centering pin?
    Place the plastic end of the tool alignment pin into any of the bolt locations on the wheel hub. Next, take the loose wheel and simply align one of the lug holes from the wheel to the alignment pin. This pin will then guide the wheel onto the hub allowing for the rest of the lug pattern to fall in place.
    You can now remove the alignment pin and proceed to install the bolts. Remember to hand start each bolt before using a power tool. This will prevent the potential to cross thread the bolts. Tighten the bolts in a cross or star pattern and please remember to torque to factory specifications. Refer to your maintenance or Bentley manual for these torque specs.
    Pic from E30 https://bimmertips.com/oem-bmw-wheel...-pin-tool-kit/
    I don't have it.
    Jul 2004
    the alignment pin
    I just take a larger needle-nose and put it through a bolt hole, and align with the hub hole. Once in the hole, push the needle nose all the way in, and maybe rock a bit: its triangular shape aligns the wheel.
    deleted air conditioning
  1. Replies: 1
    Last Post: 02-06-2009, 07:14 PM
  2. Steering wheel centering
    By russiankid in forum 5 Series BMW
    Last Post: 11-21-2008, 04:42 PM
  3. Wheel alignment
    By Mas (UK) in forum 5 Series BMW
    Last Post: 03-28-2008, 07:19 PM
  4. M60 Camshaft Alignment Tool Loaner Anyone?
    By Evan in forum 5 Series BMW
    Last Post: 08-27-2007, 12:05 PM
  5. Wheel Alignment
    Last Post: 03-25-2004, 06:35 PM
