Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Bilstein internal bushing cut
    Jul 2004
    Default Bilstein internal bushing cut
    And found that this eliminated bottoming out. I have Eibach springs and no rubber rings under and above the suspension springs at front. The car seems to have gone lower after the cut, suggesting that the bushings were on the way. Approximate length cut off - 4 centimeters:
    deleted air conditioning
    looks good mate
    Jul 2004
    Quote Originally Posted by BigKriss View Post
    looks good mate
    thanks Kris
Size:  96.1 KBName:  Strut1.jpg
Size:  90.8 KBName:  StrutBottom.jpg
    Jul 2004
    bumpety-humpety
    Billies are the whip man!
    Jul 2004
    God, the first picture is so bad.
    After blowing 2 Bilstein shocks within 9 months I changed to the Boge Sachs "turbo" struts. The ride was much cleaner, not harsh like the Billies and did not bottom out, the billies still bottomed out even after chopping the bumpstop. I think the Boge Sachs is a progressive strut design since they were so much more refined yet controlled much better. I'd have to look up the shorter bumpstop I used, cost much less than the M5 stop and the height was very close.
    Jul 2004
    Jeff, would you please share the part number on these turbo struts, if you can.
    Quote Originally Posted by Rustam View Post
    36 747A
    No longer information in regards to the Sachs turbo word. Possibly a marketing gimmick years ago but this is the same part number I used.
    Here is a link to the proper bumpstops for the Sachs/Boge with lowered suspension:
    http://www.bimmernut.com/forum/showt...r-lowered-cars
  1. Bilstein internal bushing cut
    By Rustam in forum 5 Series BMW
    Last Post: 02-24-2021, 07:22 AM
  2. for internal use only - the E34 bible
    Last Post: 12-09-2008, 05:49 AM
  3. M30/535i oil pan internal view
    Last Post: 10-08-2006, 10:45 AM
  4. Replacing internal door skins
    Last Post: 01-26-2006, 04:52 AM
  5. Where does the internal rearview mirror latch on to?
    Last Post: 06-18-2004, 07:31 AM
Tags for this Thread
