Results 1 to 3 of 3
Thread: Europeantransmissions tech bulletins
    Default Europeantransmissions tech bulletins
    Just noticed that they updated their website https://www.europeantransmissions.com/shop/ and the various good tech info disappeared which they had on the old site for transmissions, just found it again
    http://www.europeantransmission.com/...MWtechinfo.htm
    Transmissions ZF4HP 22/24
    4 HP 22 Electronic Transmission
    4 HP 24 E9 Quick Diagnostics
    ZF 4 HP 22 EH Valve Information
    ZF 4HP22/24 No reverse
    ZF 4 HP22/24 harsh shift
    E34 Transmission fault code
    ZF4HP22/24 front pump leak
    BMW 20 pin connector pin layout
    Transmission Specifications
    Early Version ZF 1986-88
    Late Version ZF Pin outs 88-89
    Transmissions ZF5 HP24
    XK8, V8, XJR Damaged J-Gate gasket
    5 HP24 E Diagnostic flow charts
    XJR replacing transmission input and output seals
    XK8 Replacing transmission valve body 5HP24
    XK8 checking fluid level
    XK8 selector level cable adjustment
    5 HP24 E fluid leak at bell housing
    ZF 5HP 19
    BMW 5HP19 Transmission
    GM 4L30E
    4L30E Information
    4L30 slipping 2gear
    4L30 DTC code #40
    BMW Transmission Electronics Bulletin
    ZF 5HP30
    ZF 5 HP30 NO reverse
    A5 S650z Info
    ZF 6HP19
    6 HP19Z E90 Fundamentals
    6 HP19 Diagnostic trouble Codes (DTC)
    6HP19 Transmission Range sensor malfunction
    6HP19 Gear4 Incorrect Ratio
    ZF 6HPxx transmission replacement instructions
    ZF mechatronic replacement
    How to perform Adaptation
    ZF 5HP18
    5 HP18 NO move or delay
    ZF 5 HP18 Binding up
    What is CAN ?
    Instrument Cluster Language
    Advanced Hints and Tips
    BMW programming Hints
    750il Pin out Information
    BMW Adaptation Information
    BMW Diagnostic Trouble Codes
    BMW Transmission Fluid level check
    Code Description DSC
    Transmission Oil Application Chard
    Important Torque Converter installation tips
    Basic Measuring Techniques
    BMW 2004 Transmission specification
    BMW Transmission EPROM update
    .E38, 39, 46, 52, 53 Instrument cluster reset
    Airbag failure codes
    EML codes repair
    EML Introduction
    WML IIIs E38, E31
    Understand the EWS system
    BMW Drive Cycle FTP72
    N62 engine update
    MSV70 Engine electronics
    BMW service indicator reset E46, E39, E53,
    BMW service indicator reset E36, E34, E32
    BMW service indicator reset E31, E30, E23, E24, E28
    BMW SIA reset E46, E38, E39, E53
    Introduction to Coding & Programming
    CVT-Mini Cooper
    Mini cooper cvt refill procedure
    Mini Cooper cvt adaptation
    Mini cooper cvt-reasembling
    Knowledge is Power, download what you need, in case the site disappears complete, copy http://www.europeantransmission.com/...MWtechinfo.htm and use the wayback machine, I downoaded it there too
    https://web.archive.org/web/20200707...MWtechinfo.htm
    Jan 2016
    Buenos Aires, Argentina
    thanks
    E34 525i '88
    ZF education video: ZF 5HP Transmission Oil Change Interval Procedure https://www.youtube.com/watch?v=S8jcRd4gyWc
  1. bulletins on the bmwtis
    Last Post: 10-22-2009, 04:24 AM
  2. Cardone tech bulletins, brake booster etc.
    Last Post: 09-08-2008, 07:50 AM
  3. Replies: 4
    Last Post: 11-08-2006, 03:44 PM
  4. M-tech 1 or M-tech 2 Steering wheel
    By Felixdacat in forum 5 Series BMW
    Last Post: 04-19-2006, 02:28 PM
  5. Replies: 3
    Last Post: 12-18-2005, 07:32 AM
