Results 1 to 5 of 5
Thread: M20 Headgasket, Losing Coolant...
    NY
    Default M20 Headgasket, Losing Coolant...
    I believe I have to replace the head gasket on my 89 525ia @ 123,000mi. I am losing about 1 quart of coolant for every 50mi of highway driving. It does not appear to be leaking anywhere outside the vehicle either. At the same time, There is no smoke whatsoever coming from the exhaust which I have always thought was a tell-tale sign of a blown headgasket. Two questions:
    1) Is there a chemical additive that I could try dumping in the radiator which might stop minor head gasket leaks?
    2) Assuming that I do have to replace the head gasket, I know I have to order the set which includes all the other gaskets/seals which need to be replaced. I was wondering if there was anything else I should consider while the head was off? I think I will do the timing belt and water pump as well, is it necessary to change the timing belt tensioner?
    Geoff
    Benneton (United Colors of)
    are you currently using the air conditioner? it probably wouldn't consume as much as 1 qt/50, but in my case recently, it was going out of the evaporator drain. also, how is your oil level? it doesn't have to be turning into milkshake for it to be mixing. is it rising as of late?
    Quote Originally Posted by ocampg
    Geoff
    NY
    I have not been using the A/C consistently, it does not seem to have any effect on the amount of coolant lost. I checked the oil, still level, still clean. I am thinking it might not be leaking in that direction, rather it may be leaking into the exhaust passages? Even still, wouldn't I see some smoke coming from the exhaust?
    a little coolent won't steam up the exhaust, if you are pumping it into the cylinder/s the cooling system will be getting pressureized by the combustion gasses
    NY
    Default Will this work?
    anybody ever try this stuff?
    http://www.rxauto.net/
  1. Replies: 4
    Last Post: 04-05-2008, 05:45 PM
  2. Losing Coolant Please Help!
    By farrk007 in forum 5 Series BMW
    Last Post: 01-07-2007, 05:15 AM
  3. Car overheated and losing coolant. Please help
    Last Post: 07-19-2004, 01:07 AM
  4. Losing Coolant
    Last Post: 03-22-2004, 05:46 PM
  5. Losing coolant...ideas?
    By TimGinCentralNJ in forum 5 Series BMW
    Last Post: 02-25-2004, 11:52 PM
