Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Anti-Lock ABS Brakes Hydraulic Pump 4 Channel - rebuildable?
    So.Calif ( L.A. Beach Area)
    Thanks I will wait until you have time to find it..TIA
    Quote Originally Posted by califblue View Post
    http://www.unofficialbmw.com/e24/bra...bs_brakes.html
    What year/model do you have?
    From preliminary reading you need to go out and lock up the brakes for the ABS to kick in. You will feel it in the peddle. After that you should be able to manually bleed the lines. The violent ABS function should cause any sticking to be released and fluid should flow on all 4 ports. I have not come across anyone with a single line that wont bleed yet but again my time is limited. I will continue to poke around and update things. Come on over and fix my radio and I'll fix your brakes...
    95 E34 530I V2.17
    I have the bosch modle 265-201-022
    i will try the lock um procedure
    Year and model car would be helpful in my research.
    This module crosses a lot of cars but nothing particular.
    Seems it should work or not work however cycling is a big fix, mostly from jamming the brakes, not so sure how that will work since you emptied an entire brake line. If the line was full with a little air pocket I can see it helping but empty might be a different story. Not sure, really doubt the ABS unis is bad.
    95 E34 530I V2.17
    I would fill the line and re-connect, then let the factory program circulate the fluid like it does when they do the service procedure used when disconnection has been done. I guess the danger is that air gets into all four lines, or upstream in the block. You never know they may have somehow designed it so that a catastrophic loss on one would isolate that line given each is controlled by discrete valves, sensing the air is all it has to do and the ABS brain could do this based on input from each valve. I'd be careful doing any ABS lockups if this means driving with the possibility of a lot of air getting into the block.
  1. Anti-lock light on
    By Spasso in forum 5 Series BMW
    Last Post: 09-10-2009, 06:11 PM
  2. Anti lock light on
    By Matt in forum 5 Series BMW
    Last Post: 08-23-2004, 06:09 PM
  3. Anti lock
    Last Post: 07-08-2004, 04:39 PM
  4. Anti-lock brakes locking up
    By mjfeeney4 in forum 5 Series BMW
    Last Post: 05-15-2004, 06:01 PM
  5. Anti-lock light on, '94 540iA
    Last Post: 02-18-2004, 06:38 AM
