Results 1 to 4 of 4
Thread: [E34] Central Lock programming
    Default [E34] Central Lock programming
    Guys,
    got 2 original keys with the car. Central lock never worked by remote. Key programming procedure pointing at the inside mirror no longer works.
    2 years ago, I tried programming both keys for central locking but everytime I succesfully programmed 1 key, the other key would stop working on remote lock.
    Now, the mirror procedure doesnt work at all. Keys are fine, batteries are fine.
    Do I need to reset something in the cars DWA to make the mirror procedure work again?
    First one with IR mirror. That initialization lock looks plausible. Time to get INPA/DIS out.
    Ok situation is about solved.|
    INPA was used to reset the initialization block. I was still not able to program my keys.
    I replaced my mirror with another mirror (IR receiver is in the mirror). I now have an auto-dimming mirror and can exclude my old IR receiver as troublemaker so its an upgrade at the same time.
    I waited a day before I tried to initialize again and I succesfully initialized 1 key. Since I did not have my spare key with me, I just have 1 key with remote for now.
    I will now arrange for 2 more keys from a junker, replace the cuts with an uncut bar and make 4 keys with remote cut to my locks. I will then (just in case) use INPA again to reset the initialization and will program all 4 of them one after the other.
    This should fix 4 keys (max is also 4)
    Possibly, the IR receiver went bad (POSSIBLY) since I was not able to initialize even 1 key after INPA reset. Changing the mirror solved that.
  1. central lock stucked at double-lock
    By nsbone_1988_520i in forum 7 Series BMW
    Last Post: 11-30-2006, 08:27 AM
  2. Central lock dilemma
    By aabdelhamid in forum 3 Series BMW
    Last Post: 10-30-2006, 09:19 AM
  3. Another pain in the a... Central lock problems
    By alikom in forum 5 Series BMW
    Last Post: 08-14-2006, 06:18 PM
  4. central lock problem! PLEASE HELP!
    By marko in forum 5 Series BMW
    Last Post: 07-11-2006, 11:29 AM
  5. HELP: central lock non-function and ABS on
    By nsbone_1988_520i in forum 5 Series BMW
    Last Post: 04-04-2005, 09:46 AM
