Page 6 of 6 FirstFirst ... 456
Results 51 to 59 of 59
Thread: the rumors of my death have been greatly exaggerated, also i own a e34 again
  1. #51
    fans may've helped mileage slightly, my drive cycle changes just enough to vary it a mpg or so, but its trending up .5 or so maybe, sooooooo nice to have consistent acceleration on a 97-99 degree drive home without the roaring fan, also doesn't drift up during extended idling but i have yet to hear the fans kick into high
  2. #52
    for whatever almost certainly unrelated to the content of the thread reason this is about to crest 2 mil views, figured id load up something fun from the show https://youtu.be/9nALL_bQm9Q
  3. #53
Size:  88.0 KBName:  IMG_1349.jpg
Size:  49.6 KBName:  IMG_1350.jpg
    started headliner project and did the front section (tourings have a 4 piece headliners vs the one piece board of a sedan) epoxied a piece of wood into the hatch to eliminate the always crap falling out panel that never fits right with aftermarket headlining material, made a hole to access the screw in event of motor failure, to replace the motor its easy enough to just take the header out. swapped in a rear light cargo area single switch dual bulb light for the standard map light style dome light.
    not wild about the color but its better then the flapping original, i can spray dye it but that would give it the texture of sand paper, i do plan to spray the sunroof panels to match, may spray the visors to match, haven't decided.
    the wrinkles seen in the fresh pics are gone the next day
  4. #54
    Quote Originally Posted by winfred View Post
    Looking good. The timber blank does nail that old chestnut fairly squarely. You can fix the e34 map+dome light, but probably best to retrofit an e39/e46 lamp or the like instead. Nothing like practical fixes like this on design issues that invariably result in ongoing PITA problems!
  5. #55
    after 9k miles in its first year it earned the 3
  6. #56
    goddamn iphone
  7. #57
    3K no issues then? Good job man!
    95 E34 530I V2.34
    right at 9000 miles the cluster finally popped up oil service, as i was changing it the 3rd time.....
  9. #59
    Feb 2007
    New Forest, ,UK,
    Let's hope your jokes have improved!
  1. Near death experiance 2X
    By Blitzkrieg Bob in forum 5 Series BMW
    Last Post: 09-18-2006, 01:57 PM
  2. Sudden Death
    By Kristuphir in forum 5 Series BMW
    Last Post: 07-15-2006, 11:25 PM
  3. VIN History/CARFAX GREATLY Appreciated
    By PTClark/'95-530i-5spd in forum 5 Series BMW
    Last Post: 05-03-2004, 03:05 PM
  4. Replies: 0
    Last Post: 05-03-2004, 08:35 AM
  5. New 3 series rumors
    Last Post: 03-22-2004, 06:46 PM
