Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 57
Thread: Radio sound dead
    May 2006
    NH
    Mine is different:
    The part under the cooling fins is not accessible, clipped in with heavy duty pop together clips. I did use a stainless brush on the solder areas I could access and it tries to come on and fizzles out. Can repeat this sometimes so I will try to reheat the solder contacts under the capacitors and see what happens.
    FWIW
    This 540 I bought came with the stock Amp removed. Looked like the PO tried to use an aftermarket Amp but I just wired the harness back onto itself bypassing the amp and the head-unit is the only power source
    one issue that may arise from this is engine whine.
    I sometimes get it using the GROM USB but not with the radio or a CD.
    You ought to be able to connect the speaker wires if you don't mind splicing so you can at least use the head unit..
    1995 540i Manual build 1/95
    No, it's the amp. A bad solder joint somewhere but fret not! Driving the wife and kid today and the radio was making staticy sounds, I mentioned that she is trying today lol. Wham! On it goes and worked for over an hour. No clue if it will work again but I am willing to say it might work for another year or so.
    Wellington,New Zealand
    just get a cd 43 they look stock!
    Quote Originally Posted by Paul in NZ View Post
    So does stock.
    I got about 6 seconds of play out of her today, most satisfying. Ordered a whole bunch of soldering equipment and supplies, looks like I'm opening an electronic repair facility. The amp board looks like it was submerged in saltwater for a decade so I will reflow the (million) solder points and hope I actually hit the problem one. If they even get a 93 or above e34 in the local pull-a-part I will just grab an amp. Until then I have a determination to fault that I intend on making this thing live again.
    Cut out one time last year for about 15 minutes and then came back on for over a year so I do have faith in it. If I had a decent camera I would take pictures to show the board but as everything is around here I am limited in technology.
    Good on ya moit! Make that ol' bugger sing!
    Here are some pics of the two I have; I did swap the Loewe like you have out for the older one I had here, but it sounds identical.
    First two pics are of the later Loewe amp, the last two the old one. Both of these work- and neither have the corrosion you described. I've found that the sound volume is low probably because the FM front end of the radio is low or its simply not very powerful. Probably better with CD. Maybe I should hook that up to see.
    I can send you my old amp (for free) if it helps- shipping from Australia for 2-3lbs won't exactly be cheap though.
    Note, the older amp fitted to M50/M60 '10 speaker Hi-Fi sound' option models are mounted on a heavier bracket. The newer one they put a hole in the middle just to save mass (see the first pic). Nice. Still, if it were Japanese, it'd be 1/10th the weight of the light one.. probably just tin straps.
    For everyone other than Jeff, this is the insides of the Loewe amp/what he is working on. Note these two models we're discussing are both booster amps, and that they lack the high power crossover first used in the previous e32/e34 (M20/M30/M70 powered) cars. The old ones were far better as you can remove the crap bit (namely the power amp) as one module. The ones we're discussing in this thread got rid of the high power crossovers. It would be good to know if it is still possible to wire in the 4 outputs of an aftermarket power amp with these. By today's standards these amps just sound crap no matter what you drive them with.
    Apart from BMW cheaping out on the first this new design, they obviously didn't feel they'd cheaped out enough. Looks like they gave the 'still expensive' Nokia ones to Loewe and said 'make a cheaper one', (Toyota style).
    I looked at retrofitting the oldest style amp (the one with the high level crossovers), however the plugs are different so it's not exactly easy to do. Maybe there is a possible mod for these new ones, so we can (somehow) use them in a similar way, ie add external amps and still use the crossovers by simply splicing into the speaker connector or the main board. Better late than never, after all...
    2 pics of the later Loewe version like Jeff's in pieces:
    Next two pic are the inside of the older Nokia model, I think this was used in most production 1993-94. It is blacker, squarer, meaner... but sounds just as bad
    May 2006
    NH
    I have a four channel Audison 30 watt (I think) amp I bought around 2001
    looks like this
    https://3284430f493d1f5bbf3c-7fcb801...9a749c3ca7.jpg
    Do you think such a thing could be worth rigging to the CD43?
    So does stock.
    Feb 2017
    Had the same problem and that's because the amp got fried.
    Quote Originally Posted by rbrickman View Post
    It is so hit and miss I get excited when I get sound. Kinda like a go-cart with a radio. Got all my solder stuff but a couple hundred reflows makes me want to clean gutters or powerwash porches and decks or the siding or look for an oil leak etc... you know.
    In mine I just realised the right side tweeter is not working.
    Will swap the amp back to the late version and see if its the right amp HF channel, or if I need to test the tweeter or wiring.
  10. #20
    So I can use the older amp, is it plug and play?
  1. Radio dead after telephone removal / OBC PPPP Code
    Last Post: 03-20-2018, 10:40 PM
  2. No sound from Radio
    By caf2461 in forum 5 Series BMW
    Last Post: 09-10-2012, 07:40 PM
  3. Radio turns on, but no sound?
    Last Post: 08-21-2007, 04:29 PM
  4. OEM radio has power, no sound...
    By 91bmw525i in forum 5 Series BMW
    Last Post: 03-03-2005, 02:06 PM
  5. factory radio is dead...what works with the changer?
    By RIPN RAY in forum 5 Series BMW
    Last Post: 12-30-2004, 12:17 AM
