Page 1 of 6 123 ... LastLast
Results 1 to 10 of 57
Thread: Radio sound dead
    Default Radio sound dead
    Happened a few months ago and after 20 minutes it was alive. Worked fine till 2 days ago, then it came back and then not.
    Not much time to check but it has to be the power amp. All radio functions. changes stations and in the dash just no sound. I have been busy so haven't checked anything yet, did disconnect the battery for a while but no change with the radio.
    Possibly a bad fuse but where would it be?
    Maybe a bad capacitor, my wrenching buddy repaired his one, here in Japanese language, but the pics will explain enough http://infinitier.ddo.jp/e32/page/ma...inte_50529.htm
    I don't think it's a capacitor but that idea makes me think about a bad solder connection somewhere in the amp or a bad plug in connection back there.. It did come on today for almost a second...
    Yes, caps all die at some point. >20 years is quite excellent in any book, especially if in a car.
    My radio is quiet, as if there is no boost from the amp. It's barely loud at full volume.
    Luckily I have a spare amplifier, so I will swap that in and see if it just fixes it!
    Might take a look at the caps first tho... lol!~
    Not the connection at the amp however it is silent when unplugged. When hooked up it makes a slight bumping static sound. have to disassemble it from the bracket tomorrow to check things out.
    Mine is different:
Size:  37.1 KBName:  Amp number.jpg
Size:  37.0 KBName:  amp top.jpg
    The part under the cooling fins is not accessible, clipped in with heavy duty pop together clips. I did use a stainless brush on the solder areas I could access and it tries to come on and fizzles out. Can repeat this sometimes so I will try to reheat the solder contacts under the capacitors and see what happens.
    May 2006
    NH
    Mine is different:
    FWIW
    This 540 I bought came with the stock Amp removed. Looked like the PO tried to use an aftermarket Amp but I just wired the harness back onto itself bypassing the amp and the head-unit is the only power source
    one issue that may arise from this is engine whine.
    I sometimes get it using the GROM USB but not with the radio or a CD.
    You ought to be able to connect the speaker wires if you don't mind splicing so you can at least use the head unit..
    1995 540i Manual build 1/95
    May 2006
    NH
    I have three stock e34 540 cassette radios of unknown operational condition I am willing to send you for shipping if you are interested.
    I bought a CD43 a few years ago and am using the GROM USB unit which does USB sticks, Android phones and Bluetooth.
    Quote Originally Posted by Jehu View Post
    Thanks for the offer. I have not had a minute to even take the covers off the amp yet. I am however not liking no radio on my work drive so as soon as I can I will open this amp up. I really don't think it's the radio but it also has it's own issues. Do you have the codes for them?
    May 2006
    NH
    Dang it , been so long since I took them out I have lost track of the codes.. I will see about what I can get with the titles..I think I have all the titles for the three 540's I've owned... the dealership will give me the codes if I have the titles I hear.
  1. Radio dead after telephone removal / OBC PPPP Code
    Last Post: 03-20-2018, 10:40 PM
  2. No sound from Radio
    By caf2461 in forum 5 Series BMW
    Last Post: 09-10-2012, 07:40 PM
  3. Radio turns on, but no sound?
    Last Post: 08-21-2007, 04:29 PM
  4. OEM radio has power, no sound...
    By 91bmw525i in forum 5 Series BMW
    Last Post: 03-03-2005, 02:06 PM
  5. factory radio is dead...what works with the changer?
    By RIPN RAY in forum 5 Series BMW
    Last Post: 12-30-2004, 12:17 AM
