Results 1 to 3 of 3
Thread: Still sputter sputin 1991 e32 735i with strange idle
    Jan 2007
    Dayton Ohio
    Default Still sputter sputin 1991 e32 735i with strange idle
    Still having problems with this 1991 e32 735i. It is idling up and down.
    I have tested:
    New O2 sensor
    Full charge on battery
    Spark plugs
    rotor and rotor cap
    vacuum leak
    throttle body
    Smoked intake no leaks
    afm
    fuel pressure
    Clamp off evap system
    I have attached a link to the video.
    http://vid273.photobucket.com/albums...nny%20idle.mp4
    leads / ignition wires?
    That really sounds strange. Have you checked the fuel pump? Maybe it is going to die? At least you can check the volume like this http://bmwe32.masscom.net/sean750/fu...Regulators.htm
    Nominal data:
    The M30 fuel pump is originally Bosch 0 580 464 995
    operating pressure is 3 bar
    conveying capcity at 12 V 1.9 liter/minute
    conveying capacity against counterpressure 875 ccm/30 seconds
    Power consumption is 5A
  1. 1991 e32 735i pan gasket replacement m30 engine
    Last Post: 03-24-2021, 12:27 AM
  2. Replies: 14
    Last Post: 08-16-2018, 07:54 PM
  3. Need a driveshaft for a 1991 735i autobox
    By Kibokojoe in forum 7 Series BMW
    Last Post: 01-04-2009, 07:45 AM
  4. 535i (1991) - strange hesitancy when pulling away
    By M Malaviya in forum 5 Series BMW
    Last Post: 08-13-2006, 07:03 PM
  5. 1991 735i won't run
    By Headshrinker in forum 7 Series BMW
    Last Post: 11-11-2004, 02:47 AM
