Results 1 to 2 of 2
Thread: Official KONI strut inserts or "Cut-A-Strut" installation procedure
    Default Official KONI strut inserts or "Cut-A-Strut" installation procedure
    This is apparently a fairly popular modification where you cut the top off of E36 m3 struts, remove the guts, drill a hole in the bottom and insert a Koni Sport insert. Not only E36, but many other cars where Koni has suitable inserts
    https://www.youtube.com/watch?v=PXSnNZt3NiI
    Just for info some DIY links:
    DIY http://syclone.motocrew.com/E36/suspension.htm
    http://www.unofficialbmw.com/images/KoniProcedure.pdf
    I should have known that earlier, actually I replaced 2 years ago both my original Sachs-Boge E36 M3 front struts with
    312253 Sachs-Boge OEM - Strut Assembly; Front Left; OE Version
    312252 Sachs-Boge OEM - Strut Assembly; Front Right; OE Version
    and 'unfortunately' scrapped the old ones as both were leaking at the top with less than 50k miles, could have bought Koni sports inserts
    Nice DIY, thanks!
    Wish I hadn't cheaped out and got our Meyle Sport damper replacements now. That GC setup doesn't seem to expensive, but for me, the stock Sport (-15mm) is ok and for mum any lower would mean big problems in the supermarket carpark. But the installation is at least super easy, yay!
    If only the e32/e34 front strut had that neat removable knuckle/strut design. (I wonder if it would be possible to retrofit it somehow, i.e. by sacrificing a set of e36/e46 struts)?
  1. Replies: 13
    Last Post: 05-11-2011, 06:53 PM
  2. Replies: 5
    Last Post: 04-28-2006, 07:51 PM
  3. Leaking Koni strut
    By Anthony (M5 in Calgary) in forum 5 Series BMW
    Last Post: 11-12-2005, 10:34 AM
  4. Anyone interested in a set of Boge shocks and strut inserts?
    By pmlmotorsports in forum 5 Series BMW
    Last Post: 10-14-2004, 10:44 PM
  5. "official?" poll on georges motion
    By Paul in NZ in forum 5 Series BMW
    Last Post: 07-17-2004, 11:22 PM
