Originally Posted by
Coyote_ar
is it possible to make a hybrid using the front of my current driveshaft with the rear of the 535 so it matches the diff input?
Have to have it balanced if you mix n match.
I'm not following, you say this dif was from a 535 (a 535) what year? And what year is the car your putting it into? Too much info missing here. You should have been able to pop the side flanges off and swap them. The input flange should have been swapped (careful with the preload). I dont know why one case would be bigger than the other. As I said more info needed.
