So for the V8 M60B40 (3.0 and 4.0) in e32 and e34 there are 2 different Bosch Motronic 3.3 ECUs,
S.I. 120994(4132) ECU: #12141427162 (early DWA)
S.I. 120695(4258) ECU: #12141429145 (With column-mounted DWA module and rolling code initiated by a special transponder chip in the vehicle ignition key)
I forget, what does the S.I Reference indicate? Service indicator? Is it the number of the chip in the instrument cluster?
