Page 1 of 5 123 ... LastLast
Results 1 to 10 of 41
Thread: Hello from Spain!
    Oct 2015
    Seville (Spain)
    Default Hello from Spain!
    Hi all, I come (if the site is not suitable Tell me), my name is Ismael I'm in Seville (southern Andalusia - Spain) and have 3 years a BMW 535i E34 (1991). Also I have a problem with it I can not find solution.
Size:  80.0 KBName:  sdsd.jpg
Size:  65.7 KBName:  20131217_125902.jpg
Size:  57.1 KBName:  20140108_123417.jpg
Size:  82.5 KBName:  20140124_140721.jpg
Size:  61.4 KBName:  20140130_133752.jpg
Size:  86.4 KBName:  20140213_140635.jpg
Size:  68.5 KBName:  20140213_140702.jpg
Size:  52.4 KBName:  20140225_140053.jpg
Size:  90.7 KBName:  20140225_140106.jpg
Size:  51.9 KBName:  20140301_111117.jpg
Size:  60.1 KBName:  20140301_111128.jpg
Size:  45.0 KBName:  20140301_121451.jpg
Size:  101.7 KBName:  20140301_132807.jpg
Size:  97.8 KBName:  20140301_132814.jpg
    Oct 2015
    Seville (Spain)
Size:  53.6 KBName:  gy2ehezu.jpg
Size:  63.8 KBName:  zaja7ygu.jpg
Size:  70.7 KBName:  asa.jpg
    The problem is cold, cold start when you start your car idling is very irregular, if not accelerate and try to get out through the exhaust explodes after unsos seconds and doing well. I think it may be the wiring ...
    Has proven anything but: flowmeter, lambda probe (it is new but not original, the disconnected and remains the same), fuel pressure regulator, idle valve and UCE
    Sometimes also with warm engine speed and try not respond, going as drowned and hits a pull and suddenly goes well
    Bad idle could be an intake air leak, disconnected hose etc.
    A backfire through exhaust is almost always an electrical issue.
    If it suddenly runs fine I would look for a bad or loose electrical connector.
    Did this problem just start happening after the rebuild?
    Oct 2015
    Seville (Spain)
    A backfire through exhaust is almost always and electrical issue.
    Vacuum hoses are all new, I think so, although I'm not sure because after 2 days to have it rebuilt it. I check the electrical connectors and cables running over the injectors. I think it may be electrical problem of the temperature sensor ...
    Tomorrow I want to make a video
    Thank you very much for answering and forgive my English is the translator: \
    May 2005
    central coast nsw au
    welcome Inmy, cant help u with the problem but nice looking car though
    Oct 2015
    Seville (Spain)
    Many thanks, I have them all revised and new, all we have not seen is where it says' To the purge valve underneight the throttle ?? '' and the tube from the intake manifold ICV is not new
    Today I received the electrical system that goes up injectors and apparently everything is correct, the temperature sensor wires are frayed. I have taped well, I leave the video for ye see him better
    By the way I have just given me that I have two identical connectors. Agree that the canister valve. I have changed and then try them as the car goes, are both two pins, I have to check what color each wire carries. I only remember that one of them is yellow (you just put)
    Oct 2015
    Seville (Spain)
    Quote Originally Posted by mattyb View Post
    Many thanks matty!
    Oct 2015
    Seville (Spain)
    the background sound is dual-mass flywheel shabby
    Oct 2015
    Seville (Spain)
  1. Spain, Germany and the number 13
    Last Post: 06-30-2008, 03:17 AM
  2. E30 activities in Peņiscola, Spain
    By shogun in forum 3 Series BMW
    Last Post: 02-06-2006, 04:49 PM
  3. someone from Spain needs E32 750 parts?
    Last Post: 11-24-2005, 12:52 PM
  4. Just got back from Spain... Auto Observations
    By DaCan23 in forum 5 Series BMW
    Last Post: 02-26-2004, 07:46 PM
