Sounds like a cracked head if coolant is getting in the plug wells. Cant see how a HG would do that but hope for the best.
Edit: Double check the front by the thermostat cover and water pump.
1. *Shouldn't* (just read through the complete procedure)
2. A newer model chevy V8 with all the crap under the hood and stuffed into a sardine can, I would say your would be easier and take less time.
3. drain, fill with conventional oil. Run it easy and drain, should get most of the coolant out. Don't need to add the full 8 quarts just 6 is fine for the rinse procedure.
4. Absolutely!
5. See what your up against first. Can change the trans to the 310R its stronger than your 270R unless you already have the 310R.
