Thread: Auto-Kat Com parts search aftermarket parts
    Default Auto-Kat Com parts search aftermarket parts
    Here you can find all part numbers of the aftermarket makers which fit. http://auto-kat.com/
    For example I searched for E32 750 oil filter and the following comes out, skipped the rest as too many
    General catalog BMW 7 (E32) 750 i,iL V12 Oil Filter
    MANN-FILTER : H 943/7 x - Oil Filter From construction year: 04/1990
    MANN-FILTER : H 952 x - Oil Filter To construction year: 03/1990
    BOSCH: 1 457 429 104 - Oil Filter, To construction year: 09/1991
    BOSCH : 1 457 429 121 - Oil Filter, From construction year: 10/1991, Inner Diameter [mm]: 27, Fitting Position: Lower
    BOSCH : 1 457 429 141 - Oil Filter, From construction year: 10/1991, Inner Diameter [mm]: 36, Fitting Position: Lower
    KNECHT : OX 103D - Oil Filter, From construction year: 04/1990
    KNECHT : OX 121D - Oil Filter, To construction year: 03/1990,
    KNECHT : OX 152/1D - Oil Filter, From construction year: 04/1990
    CHAMPION : X154/606 - Oil Filter
    QUINTON HAZELL WL7242 Oil Filter To construction year: 04/1990
    FRAM : CH8157 - Oil Filter, From construction year: 04/1990,
    HENGST FILTER : E200H D22 - Oil Filter, From construction year: 04/1990
    HENGST FILTER : E80H D24 - Oil Filter, To construction year: 03/1990
    TECNOCAR : OP968 - Oil Filter, From construction year: 04/1990
    FEBI BILSTEIN : 26702 - Oil Filter, Engine Code: M 70
    UFI : 25.038.00 - Oil Filter, From construction year: 04/1990, For OE number: 11427510717
    UFI : 25.540.00 - Oil Filter, To construction year: 03/1990
    SOFIMA : S 5038 PE - Oil Filter, From construction year: 04/1990, For OE number: 11427510717
    SOFIMA : S 5540 PO - Oil Filter, To construction year: 03/1990
    MEYLE : 314 114 0004 - Oil Filter
    SWAG : 20 92 6702 - Oil Filter, Engine Code: M 70
    JAPANPARTS : FO-ECO090 - Oil Filter
    VAICO V20-0619 Oil Filter , From construction year: 09/1991
    VAICO V20-0620 Oil Filter, From construction year: 04/1990
    SKF parts Info
    SKF also has a site for finding the SKF part numbers. While on the SKF site I found a nice tool, with your VIN or car data you can find all the SKF part numbers used in your car. So I searched for a 1989 E32 750 and got all the details what I need for the 4HP24 repair in case I have a leaking shaft seal:
    front seal auto trans oil pump seal 15803
    front auto trans seal kit 15957
    rear auto trans seal 15750
    rear auto trans repair sleeve 99157 (that is the speedi sleeve)
    http://www.skfpartsinfo.com/
    Bosch car parts catalog 2015 with part numbers and specifications, for example fuel pump pressure and capacity/hour http://www.boschcataloguessa.co.za/g..._2015.html#1/z
    Hella parts search - cat-hella public Hella application search
    quite handy when you want to search for the Hella part for your BMW http://cat.hella.com/web/public/hell...onSearch.xhtml
    For example E34 540 :
    Alternator Regulator, 5DR 004 242-051,Article status: Normal, usage number: 050625; Manufacturer Restriction: Bosch; Operating voltage [V]: 14.5
    Alternator Regulator 5DR 009 728-251,Article status: Normal: Manufacturer Restriction: Valeo; Operating voltage [V]: 14.7; Alternator Number: 2542234; SG9B010; / SG12B011; SG12B012; / SG12B015; SG12B018; / SG12B021; SG12B027; / SG12B042; SG12B047; / SG12B049; SG12B060; / SG12B074; SG12B075; / SG14B016; SG14B022; / SG9B011; SG9B013; / SG9B015; SG9B018; / SG9B023; SG9B024; / SG9B042; SG12B010; / TG11C014; TG14C011; / TG14C012; TG15C043
    Alternator 8EL 737 378-001, Article status: Normal, Engine Code: M60B40
    usage number: CA1245IR; Number of Ribs: 7; Service exchange part; Alternator Charge Current [A]: 140; Pulleys: V-Ribbed Belt Pulley; Belt Pulley Ø [mm]: 45; Voltage [V]: 14
    Feb 2017
    Done saving all the info for future reference. Thanks for sharing.
  1. Auto-Kat Com parts search aftermarket parts
    Last Post: 01-13-2018, 02:33 AM
  2. 1990 BMW 535i Aftermarket parts?
    By Krenisky in forum 5 Series BMW
    Last Post: 06-29-2011, 04:45 PM
  3. Best M50 parts house ?? mindbleed search
    By Booster in forum 5 Series BMW
    Last Post: 01-06-2007, 12:14 AM
  4. Replies: 20
    Last Post: 11-14-2005, 01:54 PM
  5. Bma Auto Parts (awesome)
    By e34it in forum 5 Series BMW
    Last Post: 03-24-2005, 11:21 AM
