Page 4 of 4 FirstFirst ... 234
Results 31 to 39 of 39
Thread: 5HP18 Valve Body rebuild question
  1. #31
    Oldham, England
    The specifications and tolerances for the bores would be extremely useful. Don't suppose your specialist passed them on did he?
  2. #32
    Frank87 has some good youtubes on the 5HP18 problems and his repairs of 5HP18 https://www.youtube.com/channel/UCwW...Akos1D1WntqhQA
  3. #33
    Oldham, England
    Very interesting videos. Thanks for posting them
  4. #34
    https://www.youtube.com/watch?v=mQBPH8MF6N0
    good training youtube: ZF 5HP18 Automatic Transmission Complete Tear Down - BMW E34 525i 4K Video.
  5. #35
    One more hint, have in this year already read about 10 broken selector shift valves, mainly on 5HP18.Replacement Selector Shift Valve: 1056 327 173 (ZF Part number). The selector valve inside the valve body was originally made out of a kind of plastic/resin, that breaks on many transmissions, so you have the feeling first that shifting is hard and then you can shift and shift and nothing happens actually inside the transmission, this part is now made of a new kind of reinforced 'plastic/metal' material, also when ATF gets hot, the old material expands and shifting gets harder.
    example Selector Valve http://www.thectsc.com/products/sele...alve-84-3.html
    So basically the same problem as with the small plastic balls in the valve body which get smaller and smaller and finally disappear.
    cases I know of within last month, 1 x on an E32 730 M60B30 with 5HP18, another one on an E36 M3 with 5HP18, and one case on an E34 with a 5HP18 and another one on a E36 with 5HP18.
    That part is included in every valve body overhault kit, position 50.020 Valve Body Kit 5HP18
    To replace that part you have to remove the transmission oil pan, the trans filter, then unbolt the valve body and drop it a bit and then you can change that part. No need to disassemble the valve body, but of you want to do so, here we have some pics when we do that in my garage for valve body overhaul Deep In E32 http://e32b12.blogspot.com/search/label/5HP18
    Broken part:
  6. #36
    Nice, Frank87- thanks you for updating and clarifying the verified causes, symptoms. Not easy to do but once you get into ATs they become a challenge one can't set aside. You've done well, and not left anyone out by sharing a lot of insights.
  7. #37
    I just found this 5HP18 valve body overhaul, plenty of pics, so I add it to this thread to find it in the future when someone want to do it http://forum.roadfly.com/threads/131...aul-DIY-Part-1
  8. #38
    Additional info that I got from a specialist is that you actually shouldnt mess with the valvebody except for 2 pieces:
    - The selector (broken as shown in shoguns pic), updated design available
    - Main pressure regulator (long thick piston in main block) -> Replace it with 5HP19 MPR
    The guy said the 5HP19 regulator fits directly and seals better. This means the body holds its pressures better. I believe him because looking at the pictures, you see it is very similar.
    Other than that. After all the work I did on 5HP18 boxes hobbywise, I can really say that next time, I will immediately buy a refurbished body from ZF or a specialist and I wont mess with it myself anymore.
    I did real good and my box shifts real good but all that work and sourcing all those parts, it's just not worth it.
  9. #39
  1. 5HP30 Valve body rebuild
    By jofusfarr in forum 5 Series BMW
    Last Post: 04-03-2019, 04:13 AM
  2. Replies: 4
    Last Post: 11-14-2010, 06:03 PM
  3. 5HP30 valve body rebuild info
    Last Post: 08-06-2010, 01:15 PM
  4. 5HP18 valve body removal
    Last Post: 02-19-2007, 01:18 PM
  5. 940540i valve body rebuild?
    By floydturbo in forum 5 Series BMW
    Last Post: 11-14-2005, 08:01 PM
