Results 11 to 20 of 23
Thread: Bilstein internal bushing cut
    Jul 2004
    illustrating the width of the "shaft" here, the actual shock absorber body:
    deleted air conditioning
    Okay so what's the point of it? More travel before it bottoms out ?
    Jul 2004
    Quote Originally Posted by BigKriss View Post
    Exactly. See Jeff's first picture.
    After blowing 2 Bilstein shocks within 9 months I changed to the Boge Sachs "turbo" struts. The ride was much cleaner, not harsh like the Billies and did not bottom out, the billies still bottomed out even after chopping the bumpstop. I think the Boge Sachs is a progressive strut design since they were so much more refined yet controlled much better. I'd have to look up the shorter bumpstop I used, cost much less than the M5 stop and the height was very close.
    Jul 2004
    Jeff, would you please share the part number on these turbo struts, if you can.
    Quote Originally Posted by Rustam View Post
    36 747A
    No longer information in regards to the Sachs turbo word. Possibly a marketing gimmick years ago but this is the same part number I used.
    Here is a link to the proper bumpstops for the Sachs/Boge with lowered suspension:
    http://www.bimmernut.com/forum/showt...r-lowered-cars
    Jul 2004
    36 747A
    Thank you Jeff.
    I thought by "turbo" you meant "turbogas", as in Boge Turbogas. I saw this number 36 747A and thought the "A"
    designation in this number probably means its an Automatic as opposed to Turbo.
    Checked the Boge catalog, Turbo struts are designated with "P" (36-676-P):
    (Boge and Sachs catalogs are taken from here http://www.zf.com/corporate/en/produ.../catalogs.html)
    When I replaced the front Bilsteins I went with the Boge/Sachs turbos. To get the actual number I would have to dig through thousands of receipts. I just got this part number from a search and the number was not from me. The bumpstops number is me. I tried doing searches regarding turbo and came up with nothing. I imagine the standard Sachs/Boge are the same thing but not sure, not concentrating on this at the moment. Might check this after a trans job.
    The bump stop is on the bottom of the shock ??
    On the top between the strut and the top strut housing. I don't have a picture of this yet.
    EDIT: if your using the Bilsteins the bumpstop is internal to the strut. As pictured above with the cutting, is what I thought would fix the issue but didn't.
    Jul 2004
  1. for internal use only - the E34 bible
    Last Post: 12-09-2008, 05:49 AM
  2. video-internal-combustion-engine
    Last Post: 11-26-2006, 05:27 AM
  3. M30/535i oil pan internal view
    Last Post: 10-08-2006, 10:45 AM
  4. Internal Gearbox Repair - recommendations?
    By myles in forum 5 Series BMW
    Last Post: 09-10-2004, 05:08 PM
  5. Where does the internal rearview mirror latch on to?
    Last Post: 06-18-2004, 07:31 AM
Tags for this Thread
